What's more reliable, MSD or Duraspark ignition module
Discussion in 'General Maverick/Comet' started by mrcomet, Mar 29, 2010.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Hello Everyone,
    My Duraspark Ignition module went bad on me. Before I replace it I was wondering what you all thought about the reliability of those boxes. I have read the new made boxes can fail quite frequently and leave you stranded.
    Is the MSD 6 set-up a more reliable stand alone ignition system than the Duraspark box. I know it's more money and there are some addtional benefits ar low rpm\idle (which i could use). But before I put out the bucks I was hoping to get a comfort feeling that I can count on it.
    Thanks for your opinions....they always help:)
    **I have an HO 302 with a high lift cam (don't know the specs), GT40X Aluminum Heads, Edelbrock RPM intake, Holley 600 4 barrel
  2. Boosha
    Boosha Built to run hard
    Buckeye State
    69.5 Maverick,1964.5 Mustang,1966 T-Bird
    I've always liked my trusty ol'Duraspark box.Just like anything else,If it's made by man...it will break...(sometime)But to me the duraspark can't be beat. jmo.:)
  3. brainsboy
    brainsboy Member
    Tampa
    Its not really a choice of reliability. Both will work fine without problems.
  4. mean_maverick
    Ive had great luck with both myself.... The duraspark is a bit more cost effective though
  5. drag460
    drag460 T-Shirt guy
    El Paso, TX
  6. mean_maverick
  7. rthomas771
    High compression and high RPM all out race car then MSD. Factory or warm over street the Duraspark.
  8. Tylar Miles
    Tylar Miles Try try try let it ride..
    Lawrenceville, ga
    1993 Nissan Sentra
    After three years of daily driving the msd on the 72' is still working like new. Eats through dist caps though. lol
  9. Jamie Miles
    :yup: MSD 6AL/Blaster II TFI coil. Has around 65k on it and still works great. It's on a stock 200... seat of the pants power and around town fuel economy increase was noticeable over the Duraspark II. Still running the Duraspark II distributor.
  10. maverick75
    i got one as well! i haven't gotten around to building the engine yet but it will be the SF box with the stock duraspark I dizzy(It only had 38K miles on it and it still looks new) with a steel gear for the TFS stage 2 cam. (y)
  11. yellow75
    Tillamook Oregon
    If either goes out you are still stranded either way, duraspark would be easier to find in a small town but if you have time you can send the MSD in for a rebuild for a reasonable price. MSD is a little easier to wire in because you dont need the connectors that you have to have for a duraspark
  12. rthomas771
    ...:hmmm:...
  13. Comick76
    Comick76 Grease Monkey
    San Angelo, TX
    76 Comet
    Duraspark gets it done(make sure all wires, wire plugs, pick-up coil aren't green and nasty) I use a Accel 300+ system that I'm very pleased with. I work on lots of cars with the MSD and Mallory systems and there doesn't seem to be any problems with them. I'd say if you got the money upgrade, if not, the Duraspark is a good system.
  14. yellow75
    Tillamook Oregon
    All right wise guy :) You win but not everybody is as sharp as you
  15. 72Mavguy
    72Mavguy Member
    Tennessee
    1972 maverick, Factory 302, soon to be mav Grabber clone
    I've never had even the slightest problem out of my Mallory Unilite ignition system :) starts like a new car everytime...easiest ignition i've ever wired up too...three wires. no seperate ignition box to deal with..everything is in the distributor. you can buy a mallory coil for it but its expensive...works great with a ford coil.
