What's the trick? headers that is! Haaaa..
Discussion in 'Technical' started by superlead76, Jan 3, 2010.
  1. superlead76
    superlead76 Member
    Tampa, FL
    1972 Maverick Grabber 347!
    So I worked all day trying to get a set of headers on a new build I'm working on and the driver's side is not going. It's on my 72, 302 Grabber. I think theya re 6901 hookers but I just wanted to see if there was a trick to this. I got these off a 72 Comet in the junkyard so I know they fit. Any ideas? Thanks!
  2. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
  3. blugene
    Gotta get the car raised up high too.
  4. don graham
    Both are right. Jack the car up on jackstands as high as you can. Remove the drivers side bolt holding the engine to the stand . You might want to loosen the passengers side too. Than either jack up the engine or lift it with a hoist. If you jack it up use a board under the pan to spread the weight. BTW, Do you have power steering. If so, you also need a drop down bracket. :)
  5. superlead76
    superlead76 Member
    Tampa, FL
    Thanks guys! I do have p/s. Drop down bracket huh? I'll look into it.
  6. Bob Wiken
    Fayetteville, Arkansas
    They are cheap ($15 or so everywhere)
  7. chachie
    chachie Member
  8. brickyard67
    brickyard67 Member
    lafayette,in.
    71 maverick
    looking to put headers on my 71 grabber, 302 , putting cam,intake -4bholley-,new timing and gears, anyone recommend header type from previous experience and problems we might run into, am thinking about pulling motor and trans to install all new gaskets on bottom side to to vehicle setting in garage 6 yrs. plus, thanks.
    brickyard67@yahoo.com
  9. Earl Branham
    Lugoff, SC
    I used Flowtech 12100FLT, and they fit well, with no problems. Just have to lift the engine on the drivers side to get them in.
