What's This?
Discussion in 'General Maverick/Comet' started by kboldin, Sep 12, 2012.
  1. kboldin
    Santee, CA.
    What's this? Looks like a ground for the hood but that makes no since?? What does it do?
    (not my car, but is the pic I was looking for)
  2. rthomas771
    It's called a Hood Bond Strap. It's for radio interference suppression
  3. kboldin
    Santee, CA.
    How does it work? ( just curious how it work :hmmm: )
  4. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    PFM..........don't know, curious too.
  5. rthomas771
    I just does...it's magic
    It keeps the speaker from poping along with the ignition by better grounding the hood. Notice it is mounted close to the antenna
  6. mercgt73
    By grounding the hood you are shielding the antenna from EMF sources such as ignition and charging systems which are located under it.
    Also, by grounding the hood you are including it in the grounded body circuit. The hinges and latch could ground the hood, but they are not a guaranteed connection since they move within each other. So the tab provides that connection.
  7. simple man
    simple man Member
    Bunnell,Florida
    Mine has a little braided wire there. Now I know what it's for! :thumbs2:
    That's why trailers have a separate ground wire too. You'd think it would ground through the ball, but.......
  8. kboldin
    Santee, CA.
    Interesting, I’ve looked at thousands of old cars and never once really saw it. It’s all starting to make since, it is a ground after all!
    I had adjusted my hood about two weeks ago and developed a rattle at idle, I finally found it (the hood bond strap!).
    I also found a more detailed and technical article here http://www.worldwidedx.com/cb-antennas/24225-grounding-straps.html
    In case anybody wanted to ready more on it. I found it pretty interesting :) .
  9. 71gold
    we were talking about this the other day...if it's for "grounding" the hood, wouldn't the hood hinges and hood latch be a better ground than a piece of tin rubbing on the paint...:huh:
  10. mercgt73
    I would agree Frank, but an even better solution would be a strap. I think the straps used little teeth to scratch through the paint... but I would bet that it does not work well.
    It is similar to towing a trailer and relying on the draw bar ball to provide the ground for the trailer. Sure it works... but a dedicated, wired connection is much better.
  11. 71gold
    someone suggested it's for the AM radio...:yup:
  12. rthomas771
    Or transistor radios
  13. 71gold
    I removed mine years ago...no problems...:Handshake
    got tired of people asking...what it was or asking...don't that scratch the paint off the hood...:tiphat:
  14. kboldin
    Santee, CA.
    Sorry about that :hide: I do appreciate all of the explanations though!
  15. 71gold
    I'm sorry...that was not directed at you...:Handshake
