Wheel and Tire database idea...
Discussion in 'Wheels and Tires' started by mercgt73, Feb 22, 2011.
  1. mercgt73
    Some have mentioned a need to consolidate the different wheel and tire combos that users are/have used. So I whipped up this GUI as a front end to a simple database to help bring this information together in a user friendly manner. Im thinking it would be run from a simple web-server so everyone can access it to add his or her information, along with a database viewer to display the information.
    What do you think so far?
    What should I add/remove?
    Remember, this is just to enter/edit wheel and tire information, I have not messed with the viewer as of yet. There will ofcourse be some buttons on the bottom, like Submit, Quit, etc.
  2. mean_maverick
    so far so good (y)
  3. maverick75
    Looks great! Especially the special notes, where we can add if a different rear end is used, what brakes,lowering mods,etc...
  4. maverick75
    Another thing to note is the make and model of the tire, Since it does matter.
  5. mercgt73
    Good idea. I'll add that in.
    I was also trying to add big tire sizes for slicks... but then I figured that required tubbing, which kinda defeats the purpose of this tool anyway. So for now I am going to exclude non traditional tire sizes.
  6. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    What if we dont know our backspacing?
  7. mercgt73
    You can get the BS by measuring the wheel. The best way is to remove it.
    So what I don't know is how forgiving the form should be. Obviously having all the information is most beneficial.
    What do you think?
  8. mercgt73
    Here is the GUI so far. Im gonna compile it and start working on the python for it. I put in a staggered check box, so if you are running the same sizes front and back, then you only have to enter the info into the fist box, and it will change to read "Front and Rear Wheel and Tires Sizes" or whatever. The lower box will be greyed out, etc.
    Any other ideas?
  9. sgaugeguy
    sgaugeguy Bob Kraus
    WILLIAMSTOWN NJ
    Could there be a spot to paste a side and rear profile of your car without posting a link? If you see the picture first and like the look you can then check out the info to achieve the same look for your car.
  10. mercgt73
    That makes sense, I can try to implement that.
  11. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    definaly good idea
    i was about to post up the same type of thread but if you can get a layout like that that be better then constantly editing the first main post to peoples responces!
  12. Stefan
    Montreal, QC
    Cool idea. If you need a free place to host it, let me know.
  13. mercgt73
    Will do! :thumbs2:
  14. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    bumpidy bump :D
  15. mercgt73
    I little update, Stefan and I have been hashing out an idea for a web-based version, because my python version would be difficult to port over to the webserver. When I get time, I am working on the web-based version and the subsequent database that will store the info.
    Updates as they develope...
