wheel help!
Discussion in 'General Maverick/Comet' started by maverick656, Apr 24, 2014.
  1. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    I got 4 American racing 14x6 rims. Are they gonna rub the leaf springs or anything (front too)when i throw them on my 75 mav? And what tires should I throw on them?
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Impossible to say without the specifics of the wheels.
  3. rthomas771
    The wheel won't rub the spring...no telling what the tire will rub without knowing the size of the tire
  4. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    I was thinking 195/70/14
  5. Shorty
    Shorty Member
    Lafayette, In
    I have 245/60R14 BFG Radials on American Racing 200s wheels on my Maverick and they do not touch the springs.
    Bruce
  6. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    Do you have any spacers on it? I haven't put a tire on it yet, but even with out it it looks
    tight
  7. Shorty
    Shorty Member
    Lafayette, In
    No spacers, it's bolted right to the drum.The spacing is out a little bit from stock because I have a '70 Mustang 9" differential but when it still had the stock 8" these exact same 7" x 14" rims and 245/60x14 tires did not touch anywhere.
    Bruce
  8. Craig Selvey
    Too skinny for a 6" wide wheel in my opinion.
  9. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    How about 215/60/14? Or 225?
  10. Craig Selvey
    Those would be fine for the rear.
    I would say 205/70/14 for the front. 215/70/14 would be another choice for the front.
  11. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    Is 255 60 r14 too big for that rim?
  12. Craig Selvey
    That I do not know.
  13. Shorty
    Shorty Member
    Lafayette, In
    My front tires are 215/70x14 on a matching pair of 200s 7" x 14" wheels.
    Bruce
  14. CaptainComet
    I have a hard time imagining a 14x6 giving you a real problem fitting tires, unless it is like some of the more modern wheels that have a bunch of positive offset, moving it toward the leaf spring.
    Try mocking the bare wheel up on the rear axle, and measure the distance between the wheel and the spring. It will give us a better idea what you are dealing with. Even a "normal" old-school wheel will be closer to the spring on these cars. The rear axle is pretty narrow.
    Also, you can look up how to measure offset. Keep in mind that you are measuring from the inner surface the tire contacts, not the outside of the rim.
    You should look to tire manufacturers spec for suggested rim size. I think you will find that 225s are usually a safe fit. A 205/60/14, like you are thinking about is awfully short and will look "cartoon-ish" on your car.
