Wheel widening?
Discussion in 'General Maverick/Comet' started by Mavlover, Sep 17, 2008.
  1. Mavlover
    Mavlover Member
    N.C.
    77 Maverick and 88 Ranger GT
    Anyone ever had there Magnum 500's widened?? I would like to put 1" in the front and 2" in the back but I'm not really sure if its a good idea or not. I've got a line on a set for only $100 that are 14 x 7 and would like to have them split + widened before I blast + paint. Any thought or help is appreciated!!
    Scott
  2. bmcdaniel
    Not Magnums, but I had my Cragars widened 2" by these guys:
    http://www.weldcraftwheels.com/
    At that time, 3 years ago, it cost $100 a wheel plus shipping. I sent them UPS from PA, cost less than $20 each way to ship two wheels.
  3. grbmaverickmo
    Aquashicola, PA
    If there painted magnums I have a guy that can do it but he`s in pa
  4. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Check with Stockton wheel. I'm sure that they can do it also.
  5. bmcdaniel
    When I checked with Stockton they didn't widen the wheels by adding a band, they remove the center and then weld it into a wider rim. They're in Cali so shipping from back east is 3 times what shipping to the midwest was.
  6. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I would check around locally.......we have a small shop here that does it.
    Check with a local speed shop, they could likely point you in the right direction.
  7. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Barry, that looks like a quality outfit. I really like the way they show how they widen the wheels. I have a set of factory aluminum wheels I would like to have that done.
  8. CaptainComet
  9. Mavlover
    Mavlover Member
    N.C.
    Thanks for all the replies guys! These are painted Magnums and I already have a set of 3" bands to go on them. I like the look of a little wider rim but I don't think I've seen any pics from anyone on the board with them. Do you think maybe a welding shop might do widening?? There is one those in my area but no speed shops anywhere close.
    Scott
  10. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    I would think the main concern (next to a good weld) is balance :huh:
    if it is way out and you cannot balance them.....or worse have 2 pounds of weights on your wheels :D
  11. bmcdaniel
    How would you part the wheel? Weldcraft has a wheel lathe to split the rims. I doubt if a weld shop would have something like that.
  12. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    yes....that was part of my balance point that I was trying to made :thumbs2:
  13. bmcdaniel
    Sorry John, I'm getting slow in my old age.
  14. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    heck no.....you made the point way better than I tried to. I have a hard time articulating with a key board........cause Stefan hasn't added a spell check yet :D
