When to shift with T5?
Discussion in 'Drag Racing' started by mashori, Jun 3, 2010.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I noticed on the street that in 1st gear I can go up to about 3,000rpm and I don't notice much more acceleration or maybe I'm just scared to take it past that because it gets pretty loud. In 2nd gear I can get good power past 3K and same with 3rd and certainy 4th gear. When racing, when should I be shifting, I know people use shift lights, what would I set a shift light at if I had one? :drive:
  2. maverick75
    IIRC you got your car dyno tuned once right?
    Look at your graph that will tell you when to shift :drive:
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    this is what the dyno curve was with the C4
  4. Bryant
    man mo. that dyno shows how tired your motor is. its valve springs have to be dead. i would try 3800 rpm. then adjust it from there. did you get the shift light stuff yet?
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I never showed you all the dyno stuff did I? I got the MSD rpm switch, waiting for that in the mail. Gotta hold off a bit on the shift light but I'll get that soon.
  6. Bryant
    we can use the window switch as a shift light switch if you want. come by the shop if you have time or we can set something up in the pits on sat.
  7. PaulS
    from the looks of that dyno sheet you should be shifting between 4200 and 4500 rpm. That will put the next gear into the torque curve and not waste much acceleration in the power band.
    Take the time to make sure you are getting wide open throttle whenthe pedal is on the floor too.
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    if the window switch comes in by then I'll bring it to the tracks and i'll bring all my wiring stuff and I have some LED lights laying around.
    I am working the rest of the day, I was thinking of leaving early tomorrow morning to go hang out with jeff and then we'll meet you and keith at the track.
    so you think it would be worth it to change the springs on this engine just to see what happens?
  9. 302-72-mav
    302-72-mav Member
    sactown CA
    when i race the mav i shift a 4.500 5.000rpm MAX and i have a 3.00-1 rear gear so my gears are long
    shifting at 3.000rpm is like normal driving right
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    i have 3.25 gears and i'm shifting at 2000-2500 right now on the street normally. it's my first stick though so i'm still learning it.
  11. yellow75
    Tillamook Oregon
    Wind that baby up to about 5,500 if it will get there then power shift it, you will be putting in the 331 sooner that way :).
    When you get the 331 in you are going to have a pleasant surprize, better learn how to shift cause a stroker winds up quick
  12. 302-72-mav
    302-72-mav Member
    sactown CA
    you are a brave man for swaping the t5 and not having much background with a stick considering the $$ involved // it's faster then before with a auto trans
    with my t5 at the track i went 93mph in 3rd gear toped out at the finish line is yours that bad
    what gear ratio do you plan on putting in the rear i was thinking 370 to 389 ?? or even 411's if i find a set cheap enough
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I was talking to bryant about gears and he mentioned that I should consider higher gears for the track. buy I like having my car as a daily driver. right now I'm very happy at 3.25
  14. 302-72-mav
    302-72-mav Member
    sactown CA
    do you even use 5th gear
    with the gearing i have i will never use 5th and maybe 4th gear sometimes
    the way i look at it is maybe if i can get the car in motion easier with 380's i will save gas on the take off and still be cruising doing 80 on the freeways and it will be way faster
    in my buddies mustang t5 trans he went from 315's ? to 373's and it was way faster and would do 140-mph
  15. 302-72-mav
    302-72-mav Member
    sactown CA
    and come to think of it i think i have 3.25's
    but it could it be this bad because i have 275 60 17's on the rear ??
