Where did all the seats go??
Discussion in 'Technical' started by Chief1010, Nov 7, 2015.
  1. Chief1010
    Chief1010 Member
    Kentucky
    72 Maverick 306, 351W heads.. 75 Maverick ( parts car )... 71 Maverick ( in storage ).. 71 Torino 500 ,306, TCI Trans, Detroit Locker..
    Since the factory Maverick bucket seats are so hard to find or so over priced ( I think $900 is abit much ).. What happens to be the best alternate for bucket seats? I've seen on here before where 99 Camaro seats will work, and I know I can make anything work.. Just looking for ideas on the easiest conversion.. Thanks again..
  2. CaptainComet
    71-73 Mustang/Cougar seats are the same frame as 71-72 Mav/Comet. Unlike earlier Mustang seats, these frames are not reproduced, but easier to find. Mav seat tracks are tricky to find. I see you have a couple of 75s .... those have the hump in the floor for the catalytic converter. If you keep the floor as is, the seat tracks for the later years are different. The later Mav passenger bucket seat is also made lop-sided, inboard side higher than outboard, so an early seat will need outboard spacer blocks to level them out.
    If you get Mav bucket seat tracks, many Ford seats are a direct bolt-on, all the way into the 1990s, maybe beyond ... same bolt pattern.
    JoeB likes this.
  3. Chief1010
    Chief1010 Member
    Kentucky
    I need to update my info.. I happen to find a 72 in fairly decent shape, and since it's already a small bumper car I decided to build it instead. And put the 75 on the back burner for now..
  4. mav man
    mav man Member
    wi
    70mav
    You don't want to use Chevy parts on a Ford,that's a sin!
  5. Chief1010
    Chief1010 Member
    Kentucky
    I agree.. The Ford gods would be angry with me, and I don't want to do that..
  6. Red1972Grabber
    Northern California
    I used seats out of a '96 Mustang and the tracks from two Maverick bench seats. The tracks needed very little modification and the seats are pretty comfortable too. Now the expensive part, getting them recovered.
    Tannersg1 likes this.
  7. Chief1010
    Chief1010 Member
    Kentucky
    Thanks 4 all the help..
  8. mav man
    mav man Member
    wi
    70mav
    The last 69 mustang my Buddy did he used 2008 mustang seats we had to make mounts for them but worked out great, power seats and also retro fitted the rear seats also so it all matches, rear was allitle bit harder though.when I'm on the home computer I'll post a couple pics.
  9. mav man
    mav man Member
    wi
    70mav
    here is some pics of the 2008 mustang seats in a 69 mustang. alittle work and they could be mounted in a mav too.
    CaptainComet likes this.
