Where do I find a 50 oz flywheel?
Discussion in 'Technical' started by scooper77515, Nov 15, 2007.
  1. scooper77515
    Do these come on other model cars or do I need to get it new from a catalog or dealer?
  2. 71gold
    they are cheap...price them at an auto. trans. shop...:Handshake
    ...get the one that has the correct amount of teeth...
  3. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    And make sure it's for a C4 not a aod.I'm pretty sure the bolt pattern is different.
  4. Blown 5.0
    MS.
    1974 Maverick
    Summit or Jegs, There was never a 157 tooth 50 oz balance flywheel made by Ford. I had to have one built in 95, cost me about 400 bucks. Now you can get a name brand for 100 dollars or so. The cheap china flywheels are cheaper than that, But i would avoid these at all costs.
  5. scooper77515
    Used ok? Or do I need to find a new one?
    I am pretty sure I am looking for 50oz 157 teeth...
  6. Blown 5.0
    MS.
    1974 Maverick
    Unless you know for sure your buying a used 50 oz balance, I would buy new.
  7. Dave B
    Their not that expensive, try National Parts Depot.
  8. Earl Branham
    Lugoff, SC
    Scott; go here ( http://www.ddperformance.com/) and see what they have to offer. If you are after a manual trans flywheel, they have the Fidanza flywheel, that has the 50oz and the 20oz weights. They bolt on, and the flywheel is rebuildable. You can also get them at Summit and Jegs. Good luck.
  9. scooper77515
    Between 308 (just bragging:D) and C4 tranny. I guess that is flexplate?
  10. rayzorsharp
    Plenty of them on eBay too. (new)
  11. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
  12. baddad457
    TCI-529610 $80 thru Summit Racing.
  13. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    It depends. My C4 came from a 77 Granada, and it has the large bell that takes the 164t flexplate [dipstick in pan]. The flexplate I am using is the same one that was in the 85 T Bird I pulled the motor from, and it was hooked to an AOD. So, maybe the AOD and the large bell C4's use the same 164t flexplate. I would think a 157t flexplate with an AOD bolt pattern would be a aftermarket item.
  14. baddad457
    The AOD and Pan fill C-4's do use the same 164 tooth flexplate.
  15. tim keck
    sharps chapel,Tn
    All 302s built after 81 or so have the 50oz balance.They're easy to spot because they have one 2-4" long weight on it and straight across from the weight is an equal sized hole in the flywheel(flexplate?)
