Where do these things go??
Discussion in 'Technical' started by Jsarnold, Aug 19, 2010.
  1. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    I'm reinstalling my dash and have a couple of pieces that aren't telling me where they go. Anyone recognize them? Only have the main dash piece and dash pad in place so far Thanks for any help.
  2. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    are those the pieces that hold the wiring harness up to the dash?
  3. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Looks like radio brackets,,,
  4. tody
    tody Member
    cologne, germany
    lower piece holds the main wiring harness in place, two are used just below the instrument cluster
    don't know about the upper, but it's not a radio bracket. that's shaped differently...
  5. sam03rc
    sam03rc Member
    gates county, nc
    is the top one maybe a bracket for the defroster?
  6. Jsarnold
    '72 Sprint
    OK, that's one. I thought that's what it might be but had no clue where it went. Thanks. :thumbs2:
  7. Jsarnold
    '72 Sprint
    Maybe. I currently have the defroster tube just hanging by the bent tabs up under the dash. Thought that's how it came out but its been a while.
    Probably should have mentioned its a factory AC car.
    Thanks.
  8. topcat
    topcat Member
    Essex, England
    '71 Grabber 302
    The big L one isn't the bracket that holds the far right of the heater assembly up to the bulkhead is it? I remember there being about 5 bolts through the bulkhead and 1 fixing inside the car up to the underside of the cowl...
  9. Jsarnold
    '72 Sprint
    Could be. There is a strap toward the center of the car waiting to support the heater/AC box. Maybe the L-shaped bracket holds the right side. I'll look for a fit there. Thanks.
  10. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Is this it? Maybe a stiffener from the thin part between the ashtray and dash pod opening to the base of the dash? :huh:
  11. Craig Selvey
    Yes......that is it.
  12. Jsarnold
    '72 Sprint
    OK!! Thanks to everyone. :Handshake Jim
