where to connect the red cable
Discussion in 'General Maverick/Comet' started by lika, Sep 9, 2009.
  1. lika
    lika Señor Comet
    IA
    comet 71
    I watched the Edelbrock video for carb installation. They said not to connect the red cable on the electric choke to the coil or to the alternator. They said to connect it to the fuse box in a slot that says "key accessory" but I don't have a slot like that in my fuse box. Where can I connect the red cable?
  2. Joe Dirt
    12V switched wire
  3. Mavman72
    If you havent allready used it,there should be an accessory bung in the fuse box.It will look like a single male spade terminal or a single clip set for a round fuse.This should also be marked "ACC" Its allmost centered on the fuse box (adjacent to the center bolt in the box)This will do what you need it too.
  4. Dave B
    Or look at the factory plugs coming out of the firewall, one will have been for the factory choke. ONe of the black plugs, around the master cylinder.
  5. rthomas771
    The factory hooked the 12v supply to the 'S' terminal on the alternator.
  6. darren
    Yep, so it only has power with the engine running. Otherwise if it was hooked to an ignition feed for example the choke would heat up and open with key on and engine not running.
  7. lika
    lika Señor Comet
    IA
    comet 71
    Thanks guys
