Where to get urethane shackle bushings???
Discussion in 'Technical' started by John Holden, Sep 10, 2011.
  1. John Holden
    John Holden Member
    NJ
    Does naybody know where I can get a set of urethane shackle bushings?
  2. Dave B
    Hmmm, I just looked on Prothane's website, they don't list any.
    If you have a lathe, you could buy some Mustang ones, and turn them down to size.
    Some Cougars, and Rancheros use the same size bushing as Mavericks, if that helps in the search.
  3. Earl Branham
    Lugoff, SC
    Espo Springs and Things (espospringsandthings.com) has them.
  4. Ryan
    Ryan Ford Addict
    Phoenix Az.
    I got mine from here, http://www.performancesuspension.com/ They are here in Phoenix. I went in and the books didnt list a maverick but they looked up the stock bushing diameter somehow and then found a bushing the right diameter. That was 15 years ago, they may have listing for them by now.
  5. John Holden
    John Holden Member
    NJ
    Espo lists squat on thier web site. I sent them an email.
    Performance suspension only lists 3 urethane items for a maverick: Control arm bushings, sway bar end links and tie rod end boots. Also sent them an email.
    Does anybody have any other suggestions or know the dimensions for the maverick bushings?
  6. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Espo lists them for $3 each. :huh: Their site has changed a bit since I last visited. Click on the "Ford" tab, select model and year, and it's the 3rd item from the bottom...
  7. John Holden
    John Holden Member
    NJ
    Espo replied to my email. I ordered them today along with the fronts. The only concern I have is the size. The bushings are 1" OD and when I measure the opening in my springs I come up with 1.2" ID. Will the urethane crush when I tighten the shackle bolts and take up the space or will there be play?
  8. bmcdaniel
    That's how I got mine. Lube them up good with silicone grease or they'll squeak after awhile.
  9. John Holden
    John Holden Member
    NJ
    I wish I did have a lathe because that sounds like the best way to get some bushings that will fit snug. I'm really worried about having play at the shackles now.
  10. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Hmmmm, mine fit perfect. :hmmm: Maybe the spring eye diameter changed somewhere through the years....
  11. John Holden
    John Holden Member
    NJ
    I would agree but the springs are new.
  12. stephen
    stephen jet mechanic
    Albuquerque, NM
    69.5 Maverick
    Where did you get the springs from? I bought mine thru JC Whitney, the rear eye diameter was bigger than the stock springs.
  13. John Holden
    John Holden Member
    NJ
    Just Suspension but they were bought a long time ago.
  14. John Holden
    John Holden Member
    NJ
    I got the bushings and they fit real nice with no play. I didn't measure them but I'm pretty sure they're bigger than 1". I had a new 1" rubber bushing that I tried in the spring and it had alot of slop. So I'm pretty happy these fit! I'll measure them and post the diameter here when I get a minute.
