Which Manual Transmission
Discussion in 'General Maverick/Comet' started by RobertBailey, Aug 13, 2009.
  1. RobertBailey
    RobertBailey MCCI & MCG Member
    Lenoir City, Tennessee
    1972 Grabber Clone,1970 Maverick, 1973 Grabber, 1973 2dr, 1973 Maverick(Parts Car) 2000 Ford SD Truck PowerStroke
    I have a local mustang / older fords guy wanting to do some trading for front disc brakes. he has a couple of T-10's ....a toploader and a 3-speed OD out of a granada.
    which is the better tranny and what would be a price on the disc set ....as is pulled off the car and not cleaned up.
    Robert
  2. mean_maverick
    disc brakes are worth $200 dirty. that 3+1 OD Granada trans is worth about $200 or so, the T10 (depending on what they come out of) are worth anywhere from $200-$700 and same goes for the toploader.
    no matter how u trade, you'll probably come out on top :yup:
  3. Mavaholic
    I've had a couple of T10s. Good transmissions but the toploader is the way to go. Do you know what it came out of?
  4. RobertBailey
    Said it came out of a mustang. what gets me is that most of what I find don't have shifters and looking on ebay...new Hurst shifters cost as much as the trannys.
    Here is his craigslist ad......he is friends with another guy I have meet at the local pull-a-part. they both do older mustangs.
    http://knoxville.craigslist.org/pts/1314733509.html
    Robert
  5. mean_maverick
    if the toploader is from a 390 car then you would have to change the input shaft to run it behind a small block. but he has some good deals on some of his parts :yup:
  6. RobertBailey
    Yep I talked to him about that last night. My First car was a 74 maverick grabber an I swapped out the c4 for a toploader 4 speed with a Hurst comp shifter.
    The comet I just stripped had the 3 speed on the floor setup in it. out side of surface rust on the flywheel everything looks like I can bolt it up behind the 302 in the maverick. I'll change the throuh-out bearing and replace the seals. I am wanting to get it drivable before the rod run in september.
    If memory serves me right the 250/300 6cyl bell housing is the same as the 302....could be wrong....having more of those senior moments lately.:oops:
    Robert
  7. mean_maverick
    yup, the bell's are the same but the flywheel will be different than the SBF ones. you'll need a 157 tooth ot 164 tooth (depending on which bellhousing you have) for your V8. (if i can help, lemme know. i have both)
    but with his parts you should be able to make a good deal :yup:
  8. RobertBailey
    From the looks of the vin and all this comet was suppose to be a v8. It had the belly bar, double hump tranny mount and the v8 z-bar all hooked up. they had made a bracket to support the engine side of the z-bar....and the bar was unmodified....so I am thinking they just pulled out the v8 and dropped in the 6cyl.
    Robert
  9. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I wish they brought that here.
    It's hard to unload a pristine 3+1 here for 100 bux.
    I have picked up several for little of nothing, but apparently so can everyone else!
    I am afraid to use one as my stock 3 speed gears were too widely spaced, and the 3+1 has the same ratios on the first 3 gears. Therefore it is too wide as well, that sorta cancels out the benefit of the OD.
    I'd definately jump on a short tail SBF toploader.
    Around here one of those brings 200 bux as a worn out lump of crap.
    400 bux if it even appears to be road worthy.
  10. Mavaholic
    I've thrown away a couple of those overdrive 3 speeds. Couldn't give them away.
  11. RobertBailey
    I have both now. I removed the cover on both and looked at all the gears. every thing seemed ok..no broken teeth. the toploader input shaft has a little slop to it.
    now to find a shifter for them.
    Robert
