which porportion valve to use? on my conversion
Discussion in 'Technical' started by flynbrd, May 30, 2011.
  1. flynbrd
    flynbrd Member
    I'm running 05+ mustang 12.5 disc in the front and 98 explorer disc in the rear. So do I want the newer disc/drum valve installed or use my old drum/drum valve? I figure since both front and back are disc I should use the drum/ drum porportion valve.?
  2. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    I have granada fronts and 98 mustang rears and plan to use a mustang prop valve and ranger 4 wheel disc master cylinder.
  3. Joe Dirt
    ive been using my drum splitter block and disc master with my 4 wheel disc with no issues.
  4. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    Get an adjustable one from Summit or Rod & Custom. I have one if you want to come over and look at it.
  5. 71gold
    if your rear tires are bigger than your front...you don't need one...:thumbs2:
    i've been running...disc/disc master...no prop. valve...w/no issues...:drive:
