I'm installing a '87 351w....I was wondering which starter & flywheel do I use the I6 cyclinder starter & flywheel or a 351w starter & flywheel?
Im not familiar w/ I6 stuff, but I know you need to use the correct flywheel for the motor and bellhousing. This goes by weight and teeth for the flywheel.
The I6 flywheel/flexplate might bolt up, but it is the wrong balance. So, no... the I6 flywheel/flexplate won't work. The starter will continue to work fine if that is the bellhousing it came from. The flywheel/flexplate needs to be a 28 oz flywheel/flexplate with the same tooth count as the I6 one, again assuming you are using the I6 bell. *Flywheels are used on manual tranny, flexplate on autos. Now, if you are using a different bell than what was on the I6, then that could change the whole equation.
Correctamundo................. The actual changeover date though is even a mystery to Ford. It was sometime in the 81 to 82 model years.
