I've got a automatic C6 out of a 72'mav in decent condition and a 4 bolt AOT out of a 89 lincoln towncar.Im just getting into Transmission stuff and wanted to know if either have potential to be used with a 302 from a 85 towncar for my mav thanks.
To use the AOD you will want to consider a new cross-member, a shortened driveline, gears in the rear end between 3.89 and 4.11, a new "A" OD servo, Lokar throttle pressure cable and swapping block plates and flex plate. The yoke you have will probably work with the shortened driveline.
