Whiten up Windshield Washer reservior
Discussion in 'Cosmetic' started by dmhines, Dec 8, 2002.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Any way to whiten and clean up the original windshield washer reservoir?? How about reproduction?? I think I have seen a picture of a Torino with the same reservoir ... thanks ..
  2. Craig Selvey
    I know a 69 torino uses the same resevoir. I don't know of any repops on those. NOS ones run over $100. I don't know how to clean one. Maybe some type of plastic polish?
  3. don graham
    you might try soaking it in water with bleach in it.
  4. inline6
    inline6 Member
    try some oxy-clean in a bucket of very hot water.it cleaned mine up pretty good.
  5. RudyD
    RudyD Pretend Mechanic.
    Ft. Collins, Colorado
    1970 Maverick.
    maybe paint it white?
  6. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    I have heard that vineger and water is good at getting something like this clean.
  7. dmhines
    Cumming, GA
    Actually I have done all of the above ... Don't think it will ever get back to original but it looks alot better ... Thanks ...
    I have seen NOS lids for these on the net - but how the heck do you get the original lid off - would make it much easier to clean. It seems to be glued on ...
    Dan
  8. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    pop off the top, take out the pump motor and throw all the plastic stuff in the dishwasher!
  9. bmcdaniel
    bmcdaniel Senile Member
    I used a rag soaked with acetone then rinsed with water.
  10. tom mulloy
    tom mulloy Senior Vice President
    Green Bay, WI
    1970 Grabber
    I pried the black lid off mine and ran everything through the dishwasher. It came out clean, but I'd like to whiten it and get rid of some of the faded yellow tinge.
    What's with that ocy-clean. Is that the one that's always on infomericals? Is it any good? Thanks.
  11. Wes
    Wes Maverick Police Dept.
    Western Pennsylvania
    '76 Maverick Stallion '76 Maverick Metro Police K-9
    I've used the oxy-clean around the house and it does work. I might try it on the plastic and see what it does. By the way, if you're doing your carpets in the Mav, mix some with the cleaner. It helps get out the stains and dirt better. Just make sure you do not use a closed container after you mix it. It gives off oxygen and wil blow up a closed bottle.
  12. Earl Branham
    Lugoff, SC
    Wes; carefull....Mr. Bin Laden may hear you. Don't give him any ideas.
    Earl
  13. gsjohnson
    gsjohnson Member
    Pasadena, California
    72 Maverick 5.0 EFI
    Virginia Mustang has new washer bottles for 69/70 Mustangs that are factory Ford replacements. They are the only vendors that have any of these left. Yes, they are narrower than the Maverick bottle, but the appearance is the same(clear plastic with black lid) & two of the three mounting screws line up with the existing holes. Plus the washer motor harness will reach & plug in, unlike other replacements. They are $26.95. Phone # is 540-896-2695. It worked great on my car & looks completely factory. They were still available from Ford up until a couple of years ago. Hope this helps.
