Who can answer this one?????
Discussion in 'Technical' started by 1oldmav71, Jan 23, 2005.
  1. 1oldmav71
    1oldmav71 New Member
    hawaii
    1971 Mav. v8
    All right all you Mav. Professionals...... here's a needle in the hay stack for you..... You know where the arms for the windshield wiper come thru the crowl vent in front of the windshield????:confused: Where the windshield wiper arm actually connects.... there are rubber like seals that keeps the water from going into the crowl when it is raining.... what are those called and where can you get them????:huh: .... what i have done not wanting to pull the windshield and do the "pain in the ass job of fixing the crowl leak":banghead: covered and welded shut:coco: now just trying to find the rubber that goes around the wiper gear..... any help:confused: :hmmm:
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    It's a mystery to what the purpose of the grommet is but it is not to keep water out .. water easily comes in through the fresh air vents all along the cowl ... Also .. the rubber grommet is only on the driver side Wiper arm ... not on the passenger side. I suppose only one of the original Ford engineers could actually tell us what the purpose of it was ... They are not reproduced ... got to pull one off a junker if you want to replace it ..
  3. 71gold
    there are also "weep holes" at the base of the windshield under the trim.... if the hood to cowl "seal" is missing, water can get in there also...frank...
  4. Jean Doll
    Palmerton, PA
    It's called a thingamagig. That's what you call any odd part the engineers at Ford came up with that has no known name.:) Dohicky works too.
  5. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I wonder if replacments could be fabricated....:confused:
  6. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    I could almost see it acting like a spacer for when they lined the cowls up to be tacked down. Since the wiper arm stubs pretty much center the cowl. But that's a shot in the dark?
  7. Maverick Man
    California
    haa haa haa... remember when i asked the questions? i thought i lost one side or something :biglaugh: but yeah to know what was up with that would be kinda funny!
  8. dmhines
    Cumming, GA
    FYI ... Ford official name for the part is: Windshield Wiper Pivot Shaft Grommet - Part # D0DZ-17C582-A - parts list shows 1 per car. If anyone wants to make one here are the dimensions: 29/32" I.D. x 1" long.
  9. 1oldmav71
    hawaii
    1971 Mav. v8
    Thanks for the numbers.....
    Thanks for the numbers:bowdown: now i know to find this part is like nailing jello to a tree right????:hmmm: All help or sites to find this would make you THE MAN!!!!!:bowdown:
  10. bmcdaniel
    I thought the grommet was only used on the driver's side wiper because it's located directly over the "chimney" that feeds the air ducts. The wiper arm on the passenger side is located more towards the center of the cowl.
  11. dmhines
    Cumming, GA
    Junk yard item ... There's plenty of guys on here with parts cars that can pull one off for you ...
  12. Mavaholic
    That works for me. (y) Plus they probably save $.03 per car by not putting one on the passenger side.
  13. 71gold
    i also noticed that the pass. side wiper arm has a cover over the spring, the driver side doesn't :coco: ...frank...
  14. bmcdaniel
    Plus they probably save $.03 per car by not putting one on the passenger side...
    So since they built over 2 1/2 million Mavs and Comets they saved over $75,000. I be pi$$ed if I was a grommet saleman and Ford was my account.
  15. Craig Selvey
