Who made suggestion of rerouting serpentine belt over radiator hose?
Discussion in 'General Maverick/Comet' started by scooper77515, May 30, 2013.
  1. scooper77515
    I need to figure out what size belt to use. I think you mentioned it in the post.
    I have power steering, water pump, alternator, crank, and tensioner only. No A/C.
    I deleted the thread because it got WAY off topic. Forgot to write down the belt size.
  2. jm16
    jm16 Joe Marino
    Oak Park, MI
    1975 Comet GT
    Scott, You can always just run a string or cloth tape measure around to find length but I bet you knew that:)
  3. scooper77515
    I would have to somehow extend the tensioner and keep it extended while I measure. That thing has some pretty serious torque on it.
  4. simple man
    simple man Member
    Bunnell,Florida
    I've used a ⅜" drive ratchet and a slide over piece of pipe to do that. Push down ( or up as the case may be ) on the ratchet to set the tensioner and slide the pipe over it so it can rest on another pulley, bracket, or something strong enough to hold it. I've done that many times on those ones where you need three hands to get the belt on! :)
  5. scooper77515
    But, still need 2 more hands to run the string and measure it. Would have to be a 2 person job, or figure a way to keep it propped in an extended position.
    Whoever posted the picture of how to route the belt gave me the belts number, i think...
  6. Bryant
    ill run the string with out moving the tensioner and then get a shorter belt. i think is usually 1 inch or 1.5 inches shorter. i sense i have a shop i usually order a few of the belts in the rage and send back the ones that i dont need.
  7. scooper77515
    Bryant, goo idea. As long as i keep the receipt they will take them back.
  8. injectedmav
    injectedmav Member
    Georgia
    That may have been me. I re-routed the belt over the WP pulley the opposite of OEM to clear the lower hose. The part # I used was for AC though, so it would be too long. Pulling a string and measuring 1-1.5 in shorter is the best idea yet.
  9. scooper77515
    OK, thanks guys!
  10. Bryant
    another tip. i dont use a string or wire, i have an old really long belt that i have cut. i will rout it the way i want then i draw a line where the end crosses. then take it off and measure it.
  11. scooper77515
    I just ran my tape measure along the entire route, 80". Next belt size is 80.5" so i will try that. 6k805
  12. blugene
    Don't you need to go down with the #s? :hmmm: 6k795?
  13. Dave B
    I hope it's a cloth tape measure....
  14. scooper77515
    Gene, I need to go up just a touch, to compensate for the flex where the tensioner will push it downward.
    Nope, regular old metal one.
  15. scooper77515
    Using string that falls into the grooves, it measured at 79. Still, if I add that 1.5" we are right back at 80.5"
