Who makes/sells a nice Aluminum Radiator?
Discussion in 'Technical' started by FordManDan, Jun 5, 2004.
  1. FordManDan
    FordManDan Member
    California (Central Valley)
    1971 Maverick Grabber. Family owned since day one. 64K orginal miles!
    I have a 1971 Maverick.
    I am looking for a nice Aluminum radiator that is more or less a bolt in that looks nice and doesn't require me to drill new holes to mount it. I'm sure the BE-COOL would work but it's $550-ouch.
    Are there any others out there? If not, what are some options?
    Thanks, Dan
  2. Bluegrass
    Bluegrass Jr. mbr. not really,
    Easton, Pa
    73 Comet GT, EFI, C4, Posi
    You can have one custom made by ART'S radiator in Flemington,N.J.
    He just done one for our sprint car.
    Key the name in your search bar to get it to come right up, for contact info.
    I believe it would be much less than 550.
  3. Cleaver
    Cleaver Member
    MD
    Chel
    Dan - try a search on "radiator" in the technical and main forum. Someone here recently just posted something about a universal fit radiator that worked. I can't remember who it was. If I find the link I will post it back here. $550 definately sounds steep. From what I have heard though, BE COOL products are a direct bolt in when you order them for a specific vehicle where some of the cheaper universal fit may require you to fabricate some spacers of have a mounting flange welded locally. I guess it depends on what you want the final product to look like and how comfortable yo are with a little light fabrication work.
    Cleaver
  4. Cleaver
    Cleaver Member
    MD
    Chel
    Dan- it was in a thread here in the technical section called "Late Model Radiators in Mavericks/Comets" that was started by Rick Book and it was Maverick-Matt that said he had a Griffith.
    Cleaver
  5. FordManDan
    FordManDan Member
    Thanks Cleaver I'll check it out.--Dan
  6. bmcdaniel
    I have an aluminum cross flow radiator, paid around $180. Only had to drill 2 holes in the upper radiator support to mount it.
  7. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    summit has aluminum radiators for around 180 I believe, I think they are griffin made, but have summits name on them, kind of like a generic brand
  8. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    Is that a racing rad or is it heavy for the street driver ?
    Richard
  9. bmcdaniel
  10. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    i ordered a Griffin Aluminum Radiator from Griffin .......it fit just like stock (y) but i think with ship it was over 530:eek: works good
  11. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
  12. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I have the same radiator that Barry has........it keeps my "little", barely over stock, with just slightly higher compression engine coooooooooooooool!
  13. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    barely over stock.. ha ha ha ha! :D
  14. valleyracer
    valleyracer Member
    Ottawa Canada
    Doe's anyone have part #s for Howe or Summit rads (measurements) to fit Mavericks?
    Richard
  15. valleyracer
    valleyracer Member
    Ottawa Canada
    Part #s...
