Who says a stock Maverick cannot handle the twisties!!!!
Discussion in 'General Maverick/Comet' started by Hotrock, Mar 6, 2017.
  1. Hotrock
    Munroe Falls, Ohio
  2. Rickeeling
    Rickeeling Member
    Clarksville Tn.
    2 door 73 Maverick with a 302
    That was pretty cool, don't think it had a stock motor. Next question, anybody know what he was saying?
  3. stumanchu
    stumanchu Stuart
    Portland, OR
    He was saying, "If these dang tires would grip and quit trying to crawl under the cross member on these turns, I would take it for more than one lap......but I love the way it burns off and does donuts.":evilsmile:
  4. Krazy Comet
    That's exactly what he was saying...
  5. 71gold
    I think it more believable if...he wore a helmet and there weren't so many road level shots of the grille...JMO
  6. Rickeeling
    Rickeeling Member
    Clarksville Tn.
    At the beginning of the Video, Bardhal is in the back ground just before get into the maverick. I looked it up, it's and oil additive company. He is in Brazil somewhere. I thought I heard "Quattro" a few times,( that's as high as I can count in Spanish) so he just might have been talking about the grip on all Four tires.
  7. CaptainComet
    Hmmmm..... hood pins and the way the car sits suggests to me that car has a few mods. I think it has at least a spring upgrade front and rear. I expected a lot more body lean. Stiffer springs were the handling trick before much better sway bars came into play.
    1973 .... probably bias belted tires. Michelin was the only company that was commonly selling radials at that time.
    If you look really close, the car starts with whitewall tires, at least on the passenger side, and it finishes with blackwalls all around. Hmmmmm.......
  8. Krazy Comet
    This is a 1973 that also has small front bumper and engine ID emblems under the maverick on front fenders, my guess it's likely a Brazilian version...
  9. Hotrock
    Munroe Falls, Ohio
    The driver was scrubbing the tires so badly the whitewalls wore off. :yup:
    TM74 likes this.
  10. 71gold
    if it's going as fast as it appears...:scratchchin:
    it also starts with...one wheel peel and ends with both tires spinning.
  11. Krazy Comet
    Once a equilibrium in traction is reached both tires will turn even with a peg leg rear...
    Guess you never air bagged or put 75psi "extra" in the RR air shock to to compensate for a open rear???
  12. spxer
    spxer Member
    Raleigh NC
    i was stuck at the elvis sideburrns lol
    71gold likes this.
  13. stumanchu
    stumanchu Stuart
    Portland, OR
    YES...those sideburns and that disco music in the opening!
