Why $25 for Manifold bolts?
Discussion in 'General Maverick/Comet' started by Bob Wiken, Aug 12, 2010.
  1. Bob Wiken
    Fayetteville, Arkansas
  2. maverick75
    theyre stronger than grade 8 google it and you cant get the tensile ratings.
  3. Bryant
    theres alot thats beter about arp. higher strengh as stated, rolled threads, smaller bolt heads for easyer access with a wrech. check there site for more info.
  4. Bob Wiken
    Is that amount of strength necessary for an intake? EFI intake are 'plastic' I could see it on heads or cranks . Just wondering
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    nope....And in my opinion its not even cheap insurance on a stock motor. No need for it unless you plan on spinning it 6 grand a 1/4 mile at a time :thumbs2:
  6. Bob Wiken
    GRRRRR, the only stud I re-used was the one where the manuel choke bracket is mounted. I got to the 3rd torque setting and broke it off. @#%^$#@%$@#
    Off to NAPA to get another one. and start all over again. IO should have done that anyway. I was right there. Bob <<<===estupido
    Saince it's 102ยบ and i 'm working in the sun it will sit til I get back from Vacation.
  7. mean_maverick
    as stated by PINKY....(y)
  8. Bob Wiken
    I just called the local ford garage to see if they had one. The parts guy I spoke to said he had a 302 block fresh from machining I can have. N/C
    My first REAL score. The stud I need is $6.40. I'm ofr to NAPA
  9. bmcdaniel
    And if you're running an aluminum manifold you should run grade 5 fasteners. The torque required to stretch a grade 8 is more than what intake manufacturers recommend.
  10. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Can you say studs!!!!!!!!!!!!!:bananaman:yup:
  11. CornedBeef4.6L
    no longer here
    Depends on the motor. 302s 351sw etc I agree 100 percent.
    Take a 4.6L with aluminum heads/block etc.....I would go expensive studs even on a basic rebuild. Less stress on threads that are much easier to strip/pullout
    I guess I would apply that on any aluminum head bolting on an aluminum intake.....
    Nothing sucks more when you are the mechanic that has to fix something like this:D
  12. CornedBeef4.6L
    no longer here
    John how steep of a set of gears do you have to do the 1/4 mile with only 6000 crank revolutions:rofl2::drive::character0182:
    Just messing with ya!!!!:evilsmile:mischeif:;):Handshake
    but the wording struck me with an odd chord!!!!
  13. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Ok maybe I'm just stupid (or work is making my brain mush today), but if RPM means revolutions per MINUTE, then wouldn't it take a 60 second quarter mile time to use up 6000 crank revolutions? :huh:
  14. Bryant
    only if your motor turns 6000 times to get you to the end of the track.
  15. Grabber5.0
    Kansas City, MO
    71 Grabber
    I knew I was forgetting something. Distance, shmistance! :D The word 'only' is what threw me off. I'm not even getting started on the meaning of steep/short/high/low. :cry: gear ratio, final drive ratio, tire size... I don't feel like doing math today. :D
