Why are fan belts all "notched" now?????
Discussion in 'General Maverick/Comet' started by mrcomet, Jul 8, 2025 at 10:52 AM.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    I have been using Dayco 41 Inch fan belts, code 15410, for the last 18 years on my 1971 comet. It is a v-belt that is solid on the underside that goes into the pulley. Now when I try to order a replacement belt they are all notched on the underside that goes into the pulley. I cannot find an automotive application belt that is not notched.
    Does anyone know why v-belts for automotive use are all notched now?????
    I tried to use the notched belt but it just made a high pitch squealing noise, even after I used belt conditioning spray.
    Thanks!!
  2. Powerband
    Powerband Member
    NY's \H/
    new belt with high pitch squeal may be a symptom . Glazed pulleys, misalignment , pulley separating, alt or WP bearing etc
    probably with the notch material from @ 10 notched belts, they can make 1 more belt and take some of that one's notches for another ...
    :cool:
    have fun
    notched belt slips less on smaller pulley radius
  3. dyent
    dyent Member
    vancouver bc
    Just for the heck of it, search and saw this.........
    "According to the U.S. Department of Energy, notched v-belts “run cooler, last longer and have efficiency about 2% higher than standard (smooth) v-belts.” Notched v-belts are optional upgrades to Quality Maintenance and Quality Renovation."
    David
