Why Does my Radiator favor the passenger side?
Discussion in 'General Maverick/Comet' started by lcrabtree, Jul 10, 2016.
  1. lcrabtree
    lcrabtree Member
    Arkansas
    76 Maverick, 95 Mustang, 65 Cobra Replica
    I'm looking to add a shroud to my radiator and noticed that may radiator sets about 2 inches off center to the passenger side. The shrouds that I'm looking at seem to mount with the fan evenly spaced with the radiator. Looks like my fan will not let it fit. My car was originally a 6 converted to 302. Could it be that the sixes had the mount holes for the radiator off center for some reason? I found one thread were the fellow had a six and had ordered a new radiator and went he went to put it on it was too far to the driver side and the upper hose fitting was hitting the fan. This seems to support different radiator supports for the 6 and v-8.
    Does anyone have a clue?
    Lester
  2. mojo
    I RECENTLY GAVE A RADIATOR FROM MY 302 TO A FRIEND W / 250 INLINE. HE BOLTED IT IN W/O ANY MODS I AM AWARE OF. DIDN'T MENTION ANYTHING ABOUT HOSE ISSUES. HOW ABOUT A PIC OF WHAT U HAVE ---- PIC WORTH 1000 WORDS..
  3. lcrabtree
    lcrabtree Member
    Arkansas
    DSCF0003.jpg DSCF0011.jpg DSCF0012.jpg DSCF0013.jpg DSCF0014.jpg Here you go, had to grill burgers before pics. My wife request grilled burgers every Sunday.
  4. Hotrock
    Munroe Falls, Ohio
    Your radiator is not OEM, it is a modified aftermarket piece. That is what is causing your fitment problem.
    Paul Masson and Fenzee like this.
  5. lcrabtree
    lcrabtree Member
    Arkansas
    Respectfully, what does that have to do with the radiator support bolts on the factory bulkhead being a different distance on each side. The aftermarket radiator is symmetrical, so why is it off to one side in the car?
    Lester
  6. 71gold
    was/is your car factory A/C?
  7. lcrabtree
    lcrabtree Member
    Arkansas
    No factory AC. The smallish radiator that is on it now is not doing a good job of cooling in stop and go traffic so I'm going with a full size radiator and hopefully a shroud. I want to figure out this offsidedness before I order.
    Lester
  8. mojo
    Are you looking for stock type copper or alum? Several bolt in choices available!
  9. Hotrock
    Munroe Falls, Ohio
    Sorry, I didn't understand your question. The Maverick/Comet radiators do mount to one side. My electric fan and shroud are centered on the water pump and off to the drivers side on the radiator.
    The following link will take you to a supplier that sells the correct fan shrouds if you are interested. You may or may not have a fitment problem with your non stock radiator or fan. The shrouds are on page 34.
    http://www.autokrafters.com/images/MV_15_Part1.pdf
  10. lcrabtree
    lcrabtree Member
    Arkansas
    Hotrock, hey thanks a bunch, just the info I was looking for. And thanks everyone else for helping.
    Lester
    NCFatBoy likes this.
  11. CaptainComet
    I believe they are all offset like that because the lines for the A/C cars need to pass by the driver side of the rad.
  12. lcrabtree
    lcrabtree Member
    Arkansas
    I wondered why they were offset like that. Thanks for the info.
    Lester
  13. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Lester
    Don't worry about rad/fan being off center... Buy /Make a blank shroud ( no fan hole ) remove fan , install shroud to radiator take a wood stick (like a stir stick) half the diameter of the fan + 3/8" see drawing. and cut to the scribe line...
      File size:
      21.1 KB
      12
  14. lcrabtree
    lcrabtree Member
    Arkansas
    Hey now, great tip. Thanks a bunch.
    Lester
