Why don't my bulb holders stay stuck in my running lights?
Discussion in 'General Maverick/Comet' started by scooper77515, Feb 23, 2014.
  1. scooper77515
    It is almost like the twist-lock holes are melted or stripped.
    I doubt they get that hot, and I doubt that the bulbs have been removed so many times that they have worn the plastic tabs down.
    All my running lights pop out of the housings and just dangle behind.
    Whats up with that?
    Going to buy new housings all around.
    Are they auto parts HELP items, or do i need to go through a mustang/maverick parts house?
  2. Moneymaker 1
    Panama City Florida
    Might could try some type of felt washers, may tighten them up enough to hold them.
  3. 71gold
    maybe the gasket is missing or has flattened out over the years...:huh:
  4. yellow75
    Tillamook Oregon
    A little dab of rtv will fix you right up
  5. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Once that plastic gets hard , They don't have the flex around the housing web .
  6. scooper77515
    I was not aware there was a gasket or flexible material. That must be the problem.
    New housings, then...
  7. CaptainComet
    Also look for cracks between the tabs. That happens a lot with side marker lights.
  8. rthomas771
    Melvin's Classic Ford Parts sells the replacement sockets if you need to replace yours
  9. scooper77515
    That is where I am going!
