will a C6 fit?
Discussion in 'Technical' started by ChadS, Oct 15, 2006.
  1. ChadS
    ChadS MacGyver Smoker
    Indiana
    70 Maverick 5.0 EFI
    Will a C6 fit in a 69.5 trans tunnel without cutting the tunnel out? Can it be swapped right in, what else can I do? Just spit my C4 out on the ground,,, its just a stock 5.0!!! lost drive, 2 and 1, has good reverse though,,, makes a noise when its in drive,,, grinding sound,,, Chad
  2. Jamie Miles
    I don't believe a C6 will fit due to the smaller trans tunnel. Of course, anything will fit with a grinder, BFH and welder... but if you don't want to do mods to tunnel, I would just get another C4 built to handle whatever power you are putting out.
  3. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    c6 prolly wouldnt fit w/o mods
    a c4 can be made to handle 1000 hp or so....c4 is lighter and is as strong as anything out there:yup:
    eddie
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Requires modification to the firewall/trans tunnel, and is too heavy to justfy using, unless you're running a big-block. C-4s are light-weight, and plenty strong when built correctly...
