Will these 15 x 8 Torq thrust fit my mav
Discussion in 'General Maverick/Comet' started by Flamesoldier, Mar 16, 2009.
  1. Flamesoldier
    Flamesoldier Member
    1973 Ford Maverick 302
    I am looking at buying two torq thrust wheels off craigslist that Are 15 x8 that have 255/60-15's and 3 3/8 back spacing these are going to go on the rear will these fit?
  2. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    Not sure about backspacing but if your car is 5 lug it should be 114.3 lug spacing on the rims for them to fit.
  3. mean_maverick
    the backspacing would scare me. if they fit, it'll be pushing it. try them b4 u buy them
  4. steven brown
    steven brown Member
    granite city il.
    1971 maverick
    what would be a good back spacing for an 8" wide rim on the rear of a maverick with a stock four or five lug 8" rear end? to clear everything with a fairly big tire?
  5. 302mav76
    302mav76 Isaac Serna
    Monterrey, Nuevo Leon, Mexico
    '76 Maverick
    4" is the safest you can go, 4.25" and the tires might rub either with the fender lip, or the frame.
  6. Demmitt
    Demmitt nutz and boltz
    Sandsprings, Oklahoma,
    1976 2 door, 1969.5 2 DOOR
    i say min tub's and you are good. there is an outstanding tec rite up on the form sounds like a strate foward task. the d' look grate on the ol mav's
  7. rthomas771
    I have 15 x 8 with 5.25 back space Center Line's on the rear...but the tires are 215x60. I had to cut the lip off the axle bumper mount where it stuck out past the frame rail. I haven't notice them flexing and hitting when in the curves yet. But I haven't took a curve aggressively yet.
    http://1bad6t.com/Maverick/mav_5066.jpg
  8. scooper77515
    Mine are 4.25 bs, and I think yours will work, but you will be limited with what rubber you can stick on em.
    Here are mine with 255/60s. On 15" rim.
  9. scooper77515
    I sure wish my garage was still that clean and had that much empty space in it...:cry:
  10. Dave B
    And I was just thinking how nice it looked! :D
  11. Flamesoldier
    Flamesoldier Member
    I dont see how they wouldnt fit? Mavman's web site says he has used 3inch and 4 inch back space with no probs. The wheels im getting are 15x8 3 3/4 backspace. I have a 15x8 with 225 70 15's on now and those are 1 once taller and 9 inch wide. the 255/60's are 10 inch wide should bolt right up no probs
  12. scooper77515
    They will bolt on no problem. But when you start slapping big rubber on there, you will start rubbing on stuff pretty quick. But I think they WILL work as long as you stick with small tires.
  13. steven brown
    steven brown Member
    granite city il.
    1971 maverick
    thanks for the info, I'm still waiting just to have a garage(LOL), my car is either in storage or at a friends house in his heated, a/c and carpeted garage for the winter. luckily I have access to a full shop with two lifts and all the tools when its time to work on it. still I would rather have my own space.
