Will these wheels fit a 5 lug mav?
Discussion in 'Technical' started by tbirdz12, Jun 4, 2008.
  1. tbirdz12
    tbirdz12 Member
    Sun Lakes, Az
    69.5 Mav
  2. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    it should as long as the backspacing will clear.
  3. Chinguschild
    Chinguschild The Bass Player
    Orcutt, Ca
    71 Grabber
    Looks like one WHEEL to me. Even the description uses wheel.
    Where do they say its a set
  4. rthomas771
    Be careful if you have disc brakes. The early style steel wheel will hit the disc brake caliper. I think the price is kinda steep for one wheel...then add shipping. You can buy a wheel at the junkyard for $5-$10 whereas that one will cost about $100 when it's all said and done.
  5. lastchance
    lastchance Member
    Hingham , Massachusetts
    Why not look for some Granada or Monarch wheels ,they will fit and clear your disc brakes and are 14 inch?
  6. newtoford
    newtoford Member
    New Castle Delaware
    i couldnt get a 68 cougar rim to fit my 5 lug mav because the holt in the middle was too small to fit over the grease cap on the front disc spindles
  7. tbirdz12
    tbirdz12 Member
    Sun Lakes, Az
    69.5 Mav
    I only need one
    Thanks
