Will this rear end work in my 71 Mav?
Discussion in 'Technical' started by Tlowery643, Apr 2, 2014.
  1. Tlowery643
    Tlowery643 Member
    Rockmart, Georgia
    Found a 8" 5 lug rearend out of a 63 Ranchero. Didn't see it on the width chart that is in one of the threads on here. Will it work and what is its width. Already been converted to disk brakes.
  2. rthomas771
    The '63 V8 Falcon has the shortest rear end...it's a quarter inch shorter than a Maverick rear end. The spring perches are the same distance as the Maverick. Only real difference is the Falcon used a 2" leaf spring whereas the Maverick used a 2.5" spring. The Falcon also used tapered axle tubes and have a smaller U-bolts than what came with a Maverick.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    In other words, you don't want that rearend for your Maverick.
  4. Tlowery643
    Tlowery643 Member
    Rockmart, Georgia
    Why? 1/4" is only 1/8 per side?
  5. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    If your on a tight budget and it's priced right you could slot the lower mounts to work with the smaller u-bolts and run it. But it's not by any means the ideal setup.
  6. Tlowery643
    Tlowery643 Member
    Rockmart, Georgia
    OK...I get you...Thanks.
  7. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Is it just the disc brakes you are after, or do you need the entire differential?
  8. Tlowery643
    Tlowery643 Member
    Rockmart, Georgia
    Right now it is 4 lug drum..Wanting 5 lug as well as disk brakes and positive traction. Looking for best economical way to go about this.
  9. jasonwthompson
    Carrollton TX
    I have a 9 inch from a Lincoln Versailles that is going into my Maverick, but it is not ready, and I am not sure when it will be as I have other Maverick priorities at the moment. Otherwise I would just give you my old 8 inch 5 lug. There is a user on here named rwbrooks50 that used to have several parts cars on his property that may be able to hook you up.
  10. John Holden
    John Holden Member
    NJ
    You may be able to swap the axles and brakes onto your stock maverick 8" rear housing. My buddy in N. Carolina would probably give you a good deal on his stock 5 lug maverick rear. His name is jski on here I believe.
  11. rthomas771
    4-lug and 5-lug housings use different O.D. and I.D. bearings. Might want to keep an eye on Pull-a-Part for a Maverick/Comet and get the rear disc off a Crown Vic.
  12. Tlowery643
    Tlowery643 Member
    Rockmart, Georgia
    Thanks and will do.
