Will TL BH fit a 3.03?
Discussion in 'Transmissions' started by LSU2010, Jul 13, 2009.
  1. LSU2010
    LSU2010 Brandon B
    Baton Rouge, LA
    '72 mav 2dr, '70 mav 2dr
    I am looking at getting a toploader bell housing. I read somewhere on the ford muscle forum that the bellhousings on those 2 transmissions were interchangeable (because it's the same case or something...idk). anyway, can I use a toploader bell housing on my 3.03? And it claims to bolt to a 65-67 289/302. Don't all sb v8 from then until now share the late windsor bolt pattern?
    here be that thread: https://www.fordmuscle.com/forums/all-ford-techboard/411067-3spd-4spd-bellhousing.html
  2. bmcdaniel
    Early '65 and older 289s had a 5-bolt bellhousing that won't mate to later 6-bolt blocks. The TopLoader tranny bolt pattern changed about the same time. Your 3.03 will bolt up to a 6-bolt bellhousing.
  3. LSU2010
    LSU2010 Brandon B
    Baton Rouge, LA
    Thank you! So the 289 and 302 until '67 was a 5 bolt and the sb were 6 bolts after that?
  4. rthomas771
    6-bolt bellhousings were born in late 65...63-64 289's were 5 bolt
  5. LSU2010
    LSU2010 Brandon B
    Baton Rouge, LA
    Thanks, Jeff. Well, I'm gonna go for this aluminum bell for my 3 speed. Let the parts frenzy continue!
