Window regulators...
Discussion in 'Technical' started by Corbin Johnson, Aug 1, 2002.
  1. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    I was wondering if window regulators are specific to one side or the other. I think they are, but I just want to make sure. Is there anyway to tell by the part numbers if they are driver's or passenger's? Thanks alot.
    -Corbin
  2. Earl Branham
    Lugoff, SC
    Corbin; wondering if you can buy the regulatory new, either reproduction or NOS. I need a driver's side regulator, so if anyone has one, let me know. Must be in good shape.
    Earl
  3. Corbin Johnson
    Wow, Earl! I have the exact same need; a driver's regulator. The crank nub that comes out of the regulator is all loose and it won't roll up easily at all. It requires two hands for operation! I'll stay on the lookout as well.
    -Corbin
  4. David
    David Member
    Ohio
    1969 1/2 Maverick 1972 Maverick
  5. Earl Branham
    Lugoff, SC
    Corbin; mine is just loose, and the window rattles when it is down. Tried tightening it up, but no good. Doesn't say if the one on ebay is drivers or passengers side. Later,
    Earl
  6. don graham
    my interchange manual dosen't metion any difference for the manual regulator, it does say that the electric regs on the other models are not interchangeable, but nothing about the manual ones. it lists 2. D0DZ6223200-1A and says this part is obsolete, then lists a D1DZ6223200A-1A. this is listed for 70-74 mavericks and 71-74 comets. sorry, this book only goes to 74. this reg is not listed on any other models. the models only list one number for the reg making no mention of driver or passenger side.
  7. Earl Branham
    Lugoff, SC
    Thanks, Don. I am wondering if they are the same as a Mustang of the same or similar year? I have a Mustang book here, and I am going to compare the part numbers.
    Earl
  8. don graham
    i have different numbers for the mustang regulators. also i just saw the reg on ebay and that number is for a 71-77 4dr sedan
  9. jeremy
    jeremy I build t5's
    Corona, Ca
    Hello earl and corbin, I guess the three of us have something in common!! a number of years back, my drivers side window got real stiff to roll up and down, finally the handle snapped right off the crank, and wallah, I need one too!
