windows off track
Discussion in 'Technical' started by 1970mavinator, Jun 6, 2010.
  1. 1970mavinator
    1970mavinator Member
    Ruskin, FL
    1970 2dr I6 maverick
    Both of my windows have recently fell off the regulator due to the plastic fasteners dry rotting and they broke. I have searched auto krafters but they dont have any. Any advice on where to get them or any tricks on how to rig them up? Thanx in advance!!
  2. Mavaholic
    Send me your address and I'll mail you a couple.
  3. 1970mavinator
    Ruskin, FL
  4. 302-72-mav
    302-72-mav Member
    sactown CA
    i used a few short bolts and some plastic and rubber washers
    works great
  5. rayzorsharp
    Not possibly as good as the correct part though. Only takes about 10 seconds to pop them in plus you don't have to worry about breaking the glass by possibly over tightening.
  6. jayss10
    jayss10 This is Minerva
    INDIANA
    1971 MAVERICK,73 GRABER CLONE
    ill buy a couple off you ,my address is jay eckelbarger 285 w 3rd st. peru, indiana 46970
  7. rthomas771
  8. rayzorsharp
    I don't think by his description that the roller is what he needs. I think he's talking about the retainer that holds the glass to the regulator. It's a two-piece plastic clip with a removable center pin that just pushes in to spread the outer retainer. I've seen pics of them posted on here before. Some Mustangs may have them too...not sure.
  9. rayzorsharp
    Here's a decent pic of what they look like.
  10. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    If I was going to use bolts, I think I'd use plastic toilet seat bolts, unless they are too big....
  11. drag460
    drag460 T-Shirt guy
    El Paso, TX
    I'm looking for a set of these, what's the name of these things? Thanks!
  12. rayzorsharp
    I call them door glass pins or retainers.
  13. injectedmav
    injectedmav Member
    Georgia
    Someone might check the Lincoln LS glass pins. they look the same. If they are reasonable, I'll order a couple to compare.
  14. fordman57
    fordman57 Member
    Hinton WV
    71 Comet
    tracks
    I used Ford Ranger window retainers its a bolt with a plastic bushing.
    Au-ve-co #19281
    Ford# F5RZ-54214116B
  15. indyman13
    indyman13 Member
    Little Rock, Arkansas
    I guesss I need to get in on this to. There's a run on plastic window clips!
