Windshield Clips question
Discussion in 'General Maverick/Comet' started by MikeG747, May 13, 2007.
  1. MikeG747
    MikeG747 Member
    Arkansas
  2. scooper77515
    They look right. I would guess they would work on all years.
  3. Craig Selvey
    They will work.
  4. MikeG747
    MikeG747 Member
    Arkansas
    Thanks guys! (y)
  5. mavtricks71
    mavtricks71 Member
    autokrafters shows a different part number for later years :|
  6. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    The yellow ones are the best. I'm going to order some tomorrow at the local auto parts suppy store. I just took all the chrome off my front and rear windows on the Grabber. I have some leaks that need to be sealed. FYI ... I have ordered these before and they are $7 for a box of 50 ...
  7. MikeG747
    MikeG747 Member
    Arkansas
    Fyi
    Guys I bought the clips Off Ebay & can not get them to work. :huh: They will not stay snaped on the studs. I snap them on & then snap my chome off & then the clip & the chrome pop off.:mad: (Anyone else had this problem?) I tried tweking them with needle nose pliers but no luck. I took the advise of another thread & ordered the #8084085's from Car Quest. I will get those tomorrow. Sounds like several people have used those successfully.:yup:
  8. dmhines
    Cumming, GA
    Are they the yellow ones? Here are the ones I highly recommend .. the brown ones suck (I don't have any of them to take a picture).
    The aftermarket are the dull yellow ones in the picture ... Ford Originals are Bright Yellow but they are the same ...
  9. Dave B
    Whats the Ford Part #?
  10. dmhines
    Cumming, GA
    Ford Part: D0DZ-6203174-C
    Auveco Part #: 10625 ... you can order these at any auto body supply shop. I get them 50 clips for like $8 ....
  11. Dave B
    When I was in Carlisle last week, I was looking at one of those clip guys booths, and he had different ones for different years of Mavericks. I wish I could remeber what the bins said, I didn't get any because the 73 bin was empty.
    I'll call my Ford parts guy tomorrow and see wht he says. Thanks for the number.
  12. dmhines
    Cumming, GA
    I can definitely tell you the yellow ones are the best. They LOCK onto the retainer in your window opening and are very difficult to get off if installed properly.
    The retaining peg must be clean ... make sure there is no window sealant or other goop on the peg or below the peg. These clips will then audibly SNAP on and be held VERY TIGHT against the window opening. Use a reveal moulding tool to pull them away from the opening as you slide your chrome into place. And yes ... installing and removing the chrome moulding is a test of patience ... use lots of masking tape for protecting your paint .... I have a 2 inch long scratch on my Grabber since I didn't use the tape.
  13. 20cows
    20cows Member
    West Texas
    74 Maverick
    My winshield seals leak.
    How DO you remove the chrome w/o tearing anything up?
