Hey guys!!! Can anyone tell me how to install the aluminum trim moldings that go on the windshield and rear window ? I have the “clips” & the trims, but just don’t have a clue on how to install them. Thanks
Those little rascals fit around the little posts in the glass channel. Once all have been fitted on the posts, then just pop the trim on. If you have never done it before, it can be confusing, or if you did not take it apart to begin with. Might be a good idea for you to take a piece of the trim and see how the clips work before you put the clips on the car. Anyways, the clips go on the posts, then the trim go on the clips. Hope this helps Dan
Thanks, we'll give it a try, and as you said, will look at the clips and trim befor inserting the clips. Thanks
