winsor heads? non mav./comet
Discussion in 'Technical' started by 71gold, Jan 21, 2006.
  1. 71gold
    a guy at work asked me to see if i could find out...what intake and gasket options he can use with...early winsor heads on a 302 block?
    he is thinking...winsor heads..302 intake and winsor gasket.
    thank you very much...frank...:bouncy:
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I think all the windsor engine family gaskets and heads interchange, only diff will be the steam holes in the 351s, and even then you can drill a 289-302 block for them . Of course you can't use a 351 intake on a 289-302 because of the increased block width, and vice versa. But any 289-302 intake should interchange.
  3. bmcdaniel
    He needs to use the 351W intake gaskets since the 351 heads have bigger ports. Use a bead of RTV at the end seals. Head and exhaust gaskets are the same as 302.
  4. papawdarrell
    papawdarrell papawdarrell
    Arkansas
    1973 Maverick
    I never drilled the block either. Maybe I was supposed to, but ran them on a stockcar, never had any problem.
  5. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Frank , in case he doesn`t know it ,he will also need to use either "stepped" head bolts (ARP makes them) or like Lorraine`s engine has, he can use the Edelbrock stepped washers Part # 9680.
    He will have to use them due to The 302 uses 7/16" head bolts ,and the 351 w uses 1/2" .
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I ran 69 Windsor heads on mine and used Felpro MS90116 intake gaskets ( 69-74 351w application). Std 302 intake, special stepped head bolts that I bought from Ford parts. I drilled the steam holes in the head not the block, used the head gasket as the template.
  7. 71gold
    thanks guys,
    i will let him know what ya'll said...frank...:bouncy:
