Winter's sidewinder shifter
Discussion in 'Technical' started by safado, Apr 11, 2025.
  1. safado
    safado Member
    West Phoenix, AZ
    Has anyone of the group installed a Winter's Sidewinder shifter? Its cable actuated and it takes two brackets on the trans side.. the rear bracket is the bracket that holds onto the outer housing of the shift cable and it goes bolted on to the two rear most servo bolts.. the problem is that the MavCom is tight in the tunnel and the bracket ends up smashing into the cross member and the chassis mount for the cross member... so just a simple notching of the cross member is not going to solve it... just seeing what others have done? I did noticed that the B&M equivalent bolts onto the lower two bolts of the same servo cover.. I was thinking of using that bracket instead but have to see if the cable fits it....
