Wiper Removal?
Discussion in 'Technical' started by MrPie68, Feb 3, 2008.
  1. MrPie68
    MrPie68 Member
    Midwest City, Oklahoma
    1969 1/2 Ford Maverick
    ok, Im sure this is a dumb question with an easy answer, lol but how do you remove the wiper arms from the actuator? I tried pulliing in the clip under the arm, but it still doesnt move. Thanks.
  2. Dave B
    You have to raise the wiper arm up from the windshield as far as it will go, then there is a little tab that you have to move outward, a small flat head screw driver works.
  3. Craig Selvey
    I don't know about any tabs????
    I pry up on the opposite side of the arm and they pop right off. Put a wooden paint stick down to pry against so you won't ruin your paint.
    They also make a special tool to remove wipers that works very well.
  4. Dave B
    Then what wiper arms am I thinking about?? Hmmmmm
  5. don graham
    are you trying to remove just the wiper for replacement or the whole assembly?:)
  6. MrPie68
    MrPie68 Member
    I got it, thanks guys. I had to remove the entire assembly for windshield removal. Thanks!
  7. Scott7141974
    Scott7141974 New Member
    Michigan
    Looking
    Cool
    Trying to take mine off they are not as easy as a Fox Body Mustang. I pushed on the clip and pulled but they are on there good. Knew if I searched here I would find a little help. Back to the garage !!:bananaman
  8. maverick75
    I used a tool that is made to remove body trim. It worked perfectly it came in the 4piece kit i got at harbor freight.
  9. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    don't mean to hijack but has anyone changed the arms to the type that will stay up when you put them up like most newer vehicles? makes it easier to clean the windshield.
