Wire Identification - Pink / Orange
Discussion in 'Technical' started by canuck222, May 12, 2020.
  1. canuck222
    canuck222 vroom, vroom... Supporting Member
    Woodstock, ON
    '73 Mercury Comet, 302, Auto
    While poking around under the dash looking for the turn signal flasher in advance of receiving a tail light kit from Easy Performance I found a disconnected pink / orange wire circled in the attached picture. Is it related to the heater and fan? I did not see a direct match on the wiring diagram and my heater controls have never worked, though I can't really see where it goes - need one of those camera bore snakes!
  2. Craig Selvey
    If the wire has "dashes" instead of a line, it is part of the seat belt system
  3. rthomas771
    I could be wrong but I think some of the emission wires have dashes also.
  4. Craig Selvey
    Yes....I think you are right. I forgot about that one.
  5. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    I have my dash apart and the speedometer pulled on my 73 LDO but sorry I do not see that wire. To the right of the steering column I see a blue with red stripe and separate beige wire, both with the female end of a connector, that go nowhere.
  6. canuck222
    Woodstock, ON
    Thanks for the input guys, I'll put the tester on it and see when it powers up.
