Wiring harness with EZ Wiring
Discussion in 'General Maverick/Comet' started by mashori, Mar 24, 2011.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    There is a company by name of EZ Wiring and they sell a 21 fuse kit for under $200 and I have been thinking about rewiring my car down the road. They offer the mini fuse kit as well for $170. What do you guys think about this kit and how hard is it to redo the wiring. Would like to put the fuse box under the hood maybe.
  2. mojo
    I have seen that company's add in my Rod & Custom mag for some years. I have been considering rewiring also. I believe they also have insturctions for wiring for Ford steering column. I don't know anyone who uses it but I wud not be afraid to try it. If I ordered it and did'nt like it I wud just return it.
    I know u did a upgrade and tech article on replacing the orig fuse panel not long ago. I followed that thread and thought u guys did a great job on documentation with that and all the rest of the upgrades you've submitted to the forum.
    For now, I added an aux fuse block that's switched side, from a relay of the battery. I will use that it gives me 12 circuits.
    I wud check w/ EZ wire and see what recommendations they have for putting it under the hood. I think it's a gud idea, a lot of the newer cars have them there. If they strongly advise agnst under hood mount, I believe Painless has a unit designed for that. If or when I rewire - under-hood will be my 1st. choice also....
  3. injectedmav
    injectedmav Member
    Georgia
    I mounted mine under the hood and if I did it again, I would put it inside the car out of sight.
  4. Joe Dirt
    I used a ez wire kit in my old thunderbird was a lot nicer then the painless wiring kits. Easy to install
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I don't think I would put the fuse box under the hood unless it is designed to be somewhat weather proof. May not make a huge difference since you are in California.
  6. injectedmav
    injectedmav Member
    Georgia
    Ron Francis makes a decent harness, also from the streetrod scene. There is also a link on his site to EFI wiring harnesses that are as close to plug and play as you can get. They were a little out of my price range, but if you have a complicated setup or a non-mainstream engine/trans combo, it's something to think about. Can't remember the name at the moment...
  7. mercgt73
    RJM? http://rjminjectiontech.com/collections/5-0l-efi-harnesses
    There is also Kwik Wire, but a harness for under $200 is a pretty good price! http://www.kwikwire.com/products.html
  8. maverick75
  9. mojo
    I have seen the Kwikwire setup B4, but did'nt recall them until u mentioned them. They have some nice components. I like the option of the replacement block TR1400 for those not wanting to run wires through the entire car but want the additional circuits along w/ the modern fuses. I can see wiring the entire car if ur gutting it and doing a total restore. For me - that's not the case.
  10. mojo
    1.) I wud like to see how u did the underhood mount. Cud u post a pix?
    2.) Why did u move it to engine bay? If u don't mind me asking.
    The only thing abt putting it inside out of sight - where wud u put it that's not real inconvient. I know some wud say for the most part, ur not going to have to access it often unless u have an electrical problem - They wud be correct.
    I just think where the fac unit is - sucks.
  11. injectedmav
    injectedmav Member
    Georgia
    I did something similar. I added the fuse box in the engine compartment to carry the additional relays for the fans, EEC, AC, etc and to eliminate the fuse links(magfuses) and a smaller bank of fuses inside that did away with the OEM fusebox, but left most of the Maverick wiring intact for lighting and accessories, column switches, etc.
