wiring on blower switch -73 mav
Discussion in 'Technical' started by Retta Ranch, Oct 23, 2008.
  1. Retta Ranch
    Retta Ranch Member
    Grandview, Texas
    1973 Maverick 2-door, 1971 Maverick 2-door. 1962 Galaxy 500
    so, we have no blower at all. dismantled everything to get to back of switches. (wanted to recover dashcap, anyway.) Found the brown wire in the 3-position switch cut, with a longer wire spliced into the end coming off the switch. It has a push on connector attached, but was just shoved into the space behind the instruments, not doing anything. There are four wires going into the switch, brown, blue, red & black from a plug. The brown is cut between the plug and the switch. Nothing is hot at the plug, either. I can get a pic if it'll help.
    Rhonda
  2. mbg1973
    mbg1973 Member
    MARIETTA, GA
    1973 MAVERICK 2DR
    the brown wire should have power. i lost power to my switch recently and it wasn't a fuse i couldnt figure it out so i just ran a new wire off the battery with an inline fuse for now.
  3. 71gold
    you may want to do a search for a ...wiring diagram...
    the blower motor switch does more than turn the fan on. in my car that switch also turns my A/C on...:yup: (is yours an A/C car/)
    ...Frank...:Handshake
  4. Retta Ranch
    Retta Ranch Member
    Grandview, Texas
    The spliced-in wire is long enough to reach the fusebox, and I wondered if that's where it was run to. I knew one of those wires was suppossed to be hot, just didn't know which one! I changed all the fuses when I first started working on it, and they're all good.
  5. Retta Ranch
    Retta Ranch Member
    Grandview, Texas
    yeah, it's got a/c, also.
    R
  6. 71gold
    i would find out why they thought they need a...jumper wire...and fix that.
    does the A/C work?
    ...Frank...:yup:
  7. Retta Ranch
    Retta Ranch Member
    Grandview, Texas
    no clue about the a/c. This electricla stuff is all new to me, I just keep searching books, asking questions here, and bugging anyone that might know :hmmm:
  8. rthomas771
    Here ya go
  9. Retta Ranch
    Retta Ranch Member
    Grandview, Texas
    Yeah!!! ya'll are awesome :yahoo: Guess you know what I'll be doing tomorrow, huh?
    Rhonda
