wiring relay for led taillights
Discussion in 'General Maverick/Comet' started by OLD GOOSE, Apr 30, 2014.
  1. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    Has anyone wired a relay for use with led tail lights and does anyone have a diagram and the name of the relay that was used the led tail lights I want to use says you have to wire the relay into the turn signals for them to work.
  2. MSmithPDX
    MSmithPDX Member
    Portland, OR
    If you used a kit and have a link for it I'll take a look and see if I can figure out what relay you need. LED's are one of those things where it could be different for every kit. Usually it's just a 12-volt standard automotive relay. I get mine at Radio Shack because they tend to be a dollar or two under the auto stores.
  3. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    no I haven't got the kit just the tail lights one wire is ground one running lights and one for turn signal That's it but it says to use a relay for the turn signals
  4. 71Mavrk
    71Mavrk Member
    Nevada
  5. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    with your info I found out what I need thanks this site is great once again someone answered my questions
