wiring ?
Discussion in 'Technical' started by 71gold, Mar 17, 2007.
  1. 71gold
    what color is the wire on the small nut on the ...left...
    ...(y) ...
  2. camcojb
    camcojb Member
    Wilton, Ca.
    on my 70 it's red with a blue stripe.
    Jody
  3. mean_maverick
    correct. most ford ignition wires for the silenoid are red/blue stripe even up until the 80's
  4. 71gold
    thank you!!! :Handshake
    ...(y) ...
    is this also the ...switched on side...?
  5. Earl Branham
    Lugoff, SC
    Frank; that was the one that was hanging on by a thread! It was red and blue stripe. Man, looks better there than I remember!
  6. bmcdaniel
    Sorry, my nut on the left is not small and there is no wire on it! :eek:
  7. mean_maverick
    yes, this is the one that activates the solenoid and engages the starter. it comes directly from the ignition switch from the 'start' position
  8. 71gold
    in that same wad of wires is a big ...yellow... and a green w/red stripe where does it go.(y)
    ...thanks for the help so far...
    when i get these wires run i will be ready to turn the power on and see if ...anything works...:cool:
  9. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The Yellow has a fusible link and attaches to the battery side of the solenoid. Are you sure the other isn't a Red with a green stripe?
  10. 71gold
    i have a ...yellow...
    a... red w/blue stripe
    a...red w/green stripe
    a...green w/red stripe
    ...:bouncy: ...
  11. maverick1970
    Missouri
    Diagrams don't show a Green w Red Stripe:hmmm:
  12. maverick1970
    Missouri
    It does show a black/orange that comes from the A terminal of the regulator
  13. 71gold
    i was thinking it might be the...idjit...light...:yup:
    ...:bouncy: ...
  14. maverick1970
    Missouri
    That should be going to the regulator
  15. 71gold
    don't got no reg.:tiphat:
    ...:cool:...
