Won't go into gear
Discussion in 'Transmissions' started by racerx, Mar 30, 2009.
  1. racerx
    racerx New Member
    Ft. Carson, Colorado
    1972 Comet 2DR
    I have a C4 from a 89 mustang and it will only go in park, reverse and nuetral. But in reverse it will stall out when I get on the accelerator hard. It will not move in any drive gear. Any suggestions?
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    First off, it may have come from a 89 mustang but it didnt come from the factory with it. First you need to identify the trans.
  3. PaulS
    You either have an AOD or someone swapped the C4 into the car.
    Is the pan small and square?
