Wont start... Electrical issue?
Discussion in 'Technical' started by RobbRudzek, May 4, 2010.
  1. RobbRudzek
    RobbRudzek Handsome Robb
    Oregon City, Oregon. Prob #13 on the top 20 most b
    1975 Maverick, inline 6... (NEW UPDATE) ... IT LIVES!!!! WHOOOT!
    when i turn my key, it makes this low buzzing noise..... errrrrrrrrrrrrrrrrrrrrrr.....
    its really lame... when i was replacing my transmission, my battery needed jumped everytime i wanted to turn it on...
    then i replaced the tranny. put everything back. and it wont turn on even if i jump it now... and no lights, wipers, or anything unless hooked up to someone elses battery....then when i jump it, try to start it, just that low buzzing noise. thats all i get.....
    so i took in the starter and the alternator to test them both...
    starter worked, alternator failed. so i replaced the alternator and it still makes that noise...
    please help. i'd really like to drive my car. lol :cry:
  2. DC12VOLT
    DC12VOLT Fuel Injected
    Everett, WA
    Cream 1971 Maverick
    You may want to replace your battery cables and clean the current ones with a wire brush. I wire brushed my terminals and connectors and it worked like a charm until now, and I'm pretty sure it's the cables. I have the same problem.
  3. rthomas771
    A dying cell in the battery also will cause these symptoms. Try a good known battery and see if it fix the problem. A battery checker won't always see if a cell is dying...only a cell that is already dead. Make sure the cables are clean, sound and tight.
  4. justin has a 74
    kentucky
    Yes indeed, my car was doing this the other day and a new battery cable and a good cleaning fixed it.
