world windsor jr heads
Discussion in 'Technical' started by NAFORD302, Jan 10, 2007.
  1. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    did anyone using these heads have header problems with the spark plugs hitting the headers :huh:
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    yea there a tight fit. I use the roush 200's. Get shorty plugs and flexible plug wires or use 90 degree boots
  3. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    yep. I got the windsor lites and it was a fun trick to make it work. I used accel header plugs and still had to dimple the tube slightly, and wrap the header in thermo wrap or the wire would burn in just a few minutes.
  4. don graham
    i use the plug boots from taylor on my plugs. i have edelbrock heads. keeps them from melting $52.95 for a set of 8 through summit.
  5. scooper77515
    On my GT40Ps (similar problem?) I use Accel Shorty Header Plugs, a spacer made out of a spare header flange (picture sent), and HEI 90degree boots on the plugs with high temp wires (that you sent me).
    I still have to jack up the engine and remove the header to do anything with the plugs, even swap wires or remove the plugs.
  6. Craig Selvey
    I am having similar problems with the Racing Head Services (RHS) Pro Action Heads.
  7. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    my question ALL these heads having troubles with spark plugs on one side...why are they made like that???
    is it the angle of the spark plug that is supposed to give you better combustion?
    im sure even in a stang or other car , its a pain to have them pointed at the header...
  8. scooper77515
    YUP. The plugs are angled more straight-in to the cylinder to center them between the valves, which means that the tip stick about 10 degrees from straight out of the head. On the pass side, this puts them right centered between the header tubes in the open space. On the drive side, it puts them right in the center of the header tube, sometimes even touch the tubes leaving no room for boots and wires.
    see pics from http://mmb.maverick.to/showthread.php?t=18214&highlight=wanna+GT40p
    PASS SIDE above DRIVER SIDE below
    These plugs are stock length and hit right at the center of the tubes, as below. Shorty plugs give you a 1/4-3/8" extra clearance, but still not enough room for plug boots.
    My solution was to take a scrap header, cut off the tubes, and put a gasket on both sides (only on the driver side) of it for extra clearance.
    Mine are iron GT40P heads, but I am assuming these other guys are hitting the same problems.
    AS for the Stang, mine came off a mercury Mountaineer or Ford Explorer, and they had a shorty header where the tubes came almost straight down from the exhaust ports, then angled together about 6 inches below the plugs, so you could easily reach the plugs. I should have grabbed those when I bought the heads, even though they probably would not have fit, I would have had them for a template for later on.
    Purely by accident, I have become a header/plug clearance EXPERT :D
  9. NAFORD302
    NAFORD302 Member
    SILEX MO
    Thanks For All The Info Please Keep All Info Coming
  10. CornedBeef4.6L
    no longer here
    welcome to hell.....:rofl2:
    I had to redo 2 tubes on my brothers usuing RHS(protoplines) still gotta make a set of 1 3/4s:rolleyes: :D
  11. eddie1975
    Martinsburg, WV
    sold
    no no find a nice 351w and put headers on it :rolleyes: you 302 guys have it made
  12. CornedBeef4.6L
    no longer here
    they have headers for you guys now so stop complaining:yup:
  13. TROG
    TROG Member
    North Carolina
    looking for a 351W Maverick
    This is very helpful information as I'm about to go look at one of these cars this Sunday. Here's the E-Bay listing:
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=008&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=180072626512&rd=1,1
    Anybody know this car by chance? He's out on the east coast of North Carolina and I will be looking VERY closely to see what kind of work room there is for this spark plug access concern! I guess I'm buying an engine lift right after I buy the car.
    Is there anyone old enough out there to remember the old Chevy Monza that came with a factory option of a 390 cu. in. engine. The thing would go like hell on wheels but the dealerships had to pull the motor just to change the plugs,....sound familiar? The only difference I can see here, is that the base price of these cars used is A LOT cheaper than the Monza when it was new,...hehehe!
    Later guys and girls...
  14. Craig Selvey
    I am using the New Doug Thorley shorties. So far....only had to ding the front 3 tubes on the driver's side, and grind away some of the mounting flange near the spark plug holes in order to get a spark plug socket to clear. It really hasn't been all that bad for having them in the car 5 times. Hopefully the sixth time in will confirm everything clears...then it is off to be recoated. 7th time on should be the final time. :)
  15. NAFORD302
    NAFORD302 Member
    SILEX MO
    what heads do you have on it
