World's Quickest Maverick
Discussion in 'New Members Forum' started by Smav347, Sep 5, 2006.
  1. Smav347
    Smav347 Member
    SoCal
    Nice to see this forum has a ton a Mav fans. My name is Jake Amatisto I work for a magazine called Race Pages. You may have heard of it. I started project Super Smaverick 2 years ago, and it's really starting to come along. I have a ton of questions so maybe all of you Maverick veterans can help me out.
    Oh and the title, does anyone know how quick I have to go to break the record??
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    First post, looks like you have been lurking for a while. Welcome
    You can click Timeslips at the top of the page for entries.
  3. don graham
    welcome to the board. we discussed your maverick a while back. if you go up to the timeslip section you'll see the timeslips of the people on here that have submitted them. good luck. also where you gonna race at. psca or brackets. where at in socal?:Welcome:
  4. Smav347
    Smav347 Member
    SoCal
    Thanks for the welcome. I figured there were some low 9-second Mavericks out there...
    Does anyone know if the Maverick's spindle setup is unique to Mavs only? I'm looking into drag brakes right now and Aerospace, Strange, and Mark Williams all offer a setup for early Mustangs and Pintos only. Would these work the same and the companies are just not listing the Mavs possibly? I know SSBC makes a kit, and I could steal a setup from a Granada, but i need something very lightweight.
  5. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    Great to have you over here. I'm a NMRA member so I know your car well. Just been waiting to see it run. You'll find answers to all your Maverick questions, including the brakes, on this forum...there's great info here.
  6. Smav347
    Smav347 Member
    SoCal
    Good to hear. I'm out of Yorba Linda, work in Costa Mesa.
    As for plans, first I will probably run Brackets or the 10.60 class in the PSCA. Then when I change the cam, ditch the transbrake, get a cage, and get some carpet I want to run PSCA Limited Street with it.
    I want to eventually build it into an Outlaw car. it will be easy to get to minimum weight in a Maverick with small-block on nitrous. Unlike the fox 10.5 Mustangs out there.
  7. ModMav71
    ModMav71 Member
    Sebring, FL
    :Welcome:
    I believe all the front suspension and brakes are the same as late 60's model Mustang so any of that should fit. We put Maverick spindles and brakes onto my Dads 68 Mustang, so putting Mustang on Maverick should work.
  8. Smav347
    Smav347 Member
    SoCal
    Oh hey man, good to hear from you. Trying to tackle the manual front steering right now. Auto Krafters sent me a center link with the holes for the tie rods drilled wrong (tapered backwards). Other than that, I was supposed to get kicked off the tra....I mean go to the track on Thursday.
  9. Smav347
    Smav347 Member
    SoCal
    Oh that is awesome news. I thought it was the same, thanks a ton.
  10. maverick1970
    Missouri
  11. rayzorsharp
    The center link is probably right. If you have a power steering gear box, you will have to change the pittman arm. I just went thru the same thing. I thought my centerlink was wrong also. Fortunately I had another car with manual steering that I just stole the complete gearbox from. You really need a manual gearbox anyway. The lock to lock ratio is quite different. It's much more difficult to turn using a power gearbox versus the manual box.
  12. Smav347
    Smav347 Member
    SoCal
    I knew I should've joined sooner! Thanks for all the info guys!
  13. Erick-Mav
    Oceanside, CA
    I changed my power steering to manual by just changing the control valve. This works great for drag cars where you don't need to turn a lot...the spool in the back will make it a little bit harder to turn too. I have no problem with my setup for the drag strip. Why did you need to get a new center link?
  14. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    welcome aboard
  15. Smav347
    Smav347 Member
    SoCal
    Well, I originally rigged it to be manual by bolting up a block off plate on the control valve. It worked fine, but I ended up bending my driver's side tie rod setup on a curb (don't ask), I figured since I needed to change the tie rods anyhow I'd convert to a manual link. It's looking like I may send it back and continue with my rigged setup. I just hate that friggin' valve!
