Would a 8.8 mustang rear ended fit. 72 Mav?
Discussion in 'General Maverick/Comet' started by Diazj7, Jan 24, 2017.
  1. Diazj7
    Diazj7 Member
    Tracy, ca
    1972 ford maverick grabber
    Would the 8.8 rear end from the Mustang fit in my
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Yes. With modification.
  3. Diazj7
    Diazj7 Member
    Tracy, ca
    Do all v8 72 Grabberr come with a 9" rear wand?
  4. greasemonkey
    Sedalia,MO
    No Maverick ever came with a 9".
  5. Diazj7
    Diazj7 Member
    Tracy, ca
    Wow I didn't that.. so how much modifications will it take to install
  6. 71gold
    shorten the tubes and axles and add spring perches...:smash:
  7. Diazj7
    Diazj7 Member
    Tracy, ca
    Seems like to much work and not enough time!! Thanks every for the great information!!
  8. Hotrock
    Munroe Falls, Ohio
    Why are you asking about installing an 8.8 in your Maverick?
  9. mojo
    what's the need to swap the 8" for 8.8" Mustang? Lot's of work/EXPENSE for nothing -IMO
  10. Diazj7
    Diazj7 Member
    Tracy, ca
    Very true that's why I'll skip on the deal
  11. mojo
    1.) What is the intended use of the car, cruiser, driver, dragster, etc.?
    2.) What drive train does it have now and what changes are planned?
    3.) What kind of shape is the exterior/interior?
    4.) Does the car run - is it street or road worthy now?
    5.) Welcome to the forum!
  12. Krazy Comet
    Uhhh a 8.8" comes close to strength of a 9"...
    Ones with 31 spline axles used in Hi-Po applications no doubt exceed the run of the mill 9" that used 28 spline axles...
  13. mojo
    Ur right, but if running a 250 or mild 302 what's the need/benfit to go thru the trouble/expense?
    Krazy Comet and 71gold like this.
  14. Krazy Comet
    Basically there is no real reason to swap in a sub 300Hp application and probably not with another 50Hp... Back in the day I did see several broken by high Hp 289 that could get traction...
  15. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Your going to want to use the explorer 8.8. Some come with 31 spline track-lok's and a decent gear. I used one and cut the long axle tube appx 2 3/4 in and ordered 2 short side axles.
