x 303 cam for stock 302 head
Discussion in 'Drag Racing' started by indabebe, May 20, 2011.
  1. indabebe
    indabebe Member
    86 nissan 720
    im getting a cam regrinded and i was wondering if the 303 is too big for a stock 87 302 head w/ stock springs?
    cause the guy recommended a 218-224 duration and 516-531 lift for street
  2. Bryant
    i really doubt the valve springs will take that type of lift. the flow of the heads will be too little to take advantage of the cam.
  3. indabebe
    indabebe Member
    86 nissan 720
    so is the 218 or 224 good?
  4. bmcdaniel
    Describe your engine/car and what you want to do with it.
  5. indabebe
    indabebe Member
    86 nissan 720
    I have a 87 302 HO ported heads, f4b intake, 650cfm 4 barrel, stock exhaust mani w/ a rebuilt c4 trans, transgo stage 2 kit.
    Im not
    Looking to race, just street that would be able to spin and burn out and have a badass staggered idle.
  6. bmcdaniel
    What rear gears? I would concentrate on the exhaust first before worrying about a cam. And the F4B, while period-correct, is not a very good intake.
  7. Joe Dirt
    E303 will be more ideal
  8. ghettoshelf
    ghettoshelf Member
    austin texas
    73 grabber 302 auto
    I agree with Joe Dirt.E303 would be better.If you just want a choppy idle and mediocre power buy the small thumper cam comp makes.You really should use the correct springs and check for valve to piston clearance on any large cam.I would worry about valve to piston clearance a lack of convertor and rear gears and poor flowing intake and exhaust on the X303.You might get the choppy idle but it would turn into a miserable turd to drive.
  9. Mr 4 Speed
    Mr 4 Speed Member
    1970 Grabber
    Why are you having a camshaft reground when new cams are inexpensive?
    As others stated, E303 if it is a roller block. Hydraulic lifter engine....use something around .470-.480" lift on the intake; .480-.490" lift on the exhaust; 218 duration @ .050" lift on the intake; 224 duration @ .050" lift on the exhaust; intake centerline around 108 degrees; 110-112 lobe separation angle.
  10. indabebe
    indabebe Member
    86 nissan 720
    Damn, I guess I can try to sell it. Ill leave it stock for now. But the rest is stock. I'm guessing 8" with 3.25? Not sure.
    I'll post the spec of what he put
