I've suposedly got everything I need for said swap. The trans is in...with the correct flexplate and I have the cables for the throttle and stuff.....but I have no idea how to hook up and adjust them.
You need a pressure gauge to adjust the cable. What cable are you using? Lokar comes with the instructions.
When I adjusted mine I found a couple youtube videos showing how to do it. I used a spare oil pressure gauge i had and screwed it into the port on the drivers side of transmission towards the front above the pan. There are two ports and i am pretty sure you tap into the top one. Can't remember what pressure to set it at though, it was in my Lokar instructions.
