your best guess please
Discussion in 'General Maverick/Comet' started by ptpdub, Sep 6, 2011.
  1. ptpdub
    ptpdub Member
    canada Sk.
    my car is getting a transmission fixed and while it is up on the lift i am trying to take care of a few things. what is your best guess on the source of a rattling noise on the front passenger side tire. happens when I go over bumps. car does not pull to the side. what is your best guess. thanks.
  2. mav1970
    Spring rubber missing or rubber in shock eyelet gonzo :)
  3. darren
    Srut rod bushings made an awful rattle over bumps in mine. Drove fine considering how bad they were when they came out.
  4. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Loose sway bar end links. Hard to say without hearing the rattle though.
  5. rthomas771
    I forgot to tighten the bottom fender bolt after adjusting my fender and it would rattle sometimes.
  6. Streamliner
    Streamliner Member
    Lugnuts in the hubcap:D
  7. ptpdub
    ptpdub Member
    canada Sk.
    aaaaah, that must be it!:rofl2:
  8. Bob Wiken
    Fayetteville, Arkansas
    I had the same noise. Bearing grease cap in the hub cap
  9. ptpdub
    ptpdub Member
    canada Sk.
    no hubcaps on this one.
  10. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    My guess is the 2 rubber isolators on the bottom bolts of the shock. Highly overlooked by most.
    Let us know what it is.
  11. Bryant
    the brake pad in the caliper. there are tabs on the out board pad that wrap around the caliper. they need to be kinda tight to keep the pad from moving around in the caliper. i will take some channel lock pliers and squeeze them tighter on the caliper.
  12. Streetdeacon
    Streetdeacon Streetdeacon
    Bellingham, WA
    1977 Maverick 2dr.
    I was going to sugest the pads are loose on the bracket. I had the same problem and that is what it was. The tabs were really hard to bend on mine though. :tiphat:
  13. darren
    Man this is a good rattle thread. Think we'll have pretty much everything covered soon.LOL.
  14. 71gold
    loose... spindle nut ...:huh:
  15. ptpdub
    ptpdub Member
    canada Sk.
    your magic crystal ball seems to be better than most. you got it right!!!
